Sway bar ?
Old 01-07-07, 08:47 PM
  #31
lifeisgood
lifeisgood's Avatar
Originally Posted by t.is350.h
If you want to get rid of the body roll, you would have to lower your car. I think sway bar is controlling under or over steering.
I'm not sure what basis you have for making your statement about body roll, but based on prior research I did before installing one on my 1966 mustang, a sway bar will help to eliminate body roll. However, too much sway bar can cause too much oversteer, and too much sway bar coupled with aggressive cornering can cause the rear end of the car to break loose unpredictably. It's all about trade-offs.
Old 01-07-07, 08:51 PM
  #32
al503
al503's Avatar
Originally Posted by JeffTsai
Whats all this negativity towards aftermarket sways in the IS crowd? It seems as if most of us guys in the GS section have upgraded sway bars. I know for sure that my car handles better with these than it did previously with the stock pieces.
I don't think it's negativity at all. The OP inquired about reducing roll. The (arguably) best way to do that is via the springs.
Stiffer sways can and do reduce roll but as mentioned previously, it may also reduce overall grip.
Old 01-07-07, 09:12 PM
  #33
Gernby
Gernby's Avatar
Big sway bars don't necessarily cause oversteer. It is the ratio in size between the front and rear that causes under / oversteer. If you put a larger front sway bar on a car, it will plow like a *****.
Old 01-07-07, 10:54 PM
  #34
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,083 Likes on 2,475 Posts
Originally Posted by Gernby
I thought the sport suspension just had different knuckles, or something. If so, it wouldn't necessarily change roll center any more than putting smaller wheels / tires on the front.
Not true. Just less ride height from the spring change. All the suspension parts are identical except springs and shocks.
BTW, ^^^ did you mean plow like a farm implement? All I can see is *****...
Old 01-08-07, 07:31 AM
  #35
Gernby
Gernby's Avatar
"Farm implement" is probably better than the explitive that I used.
abenjack
04-29-19 01:22 PM
ISFLexy
Suspension and Brakes
04-05-18 05:14 PM
bearcav
11-05-17 08:53 PM
mick_foley
11-22-07 10:46 PM
ba-b4
21
04-27-07 08:43 PM
Quick Reply: Sway bar ?
