Will TPMS Be Ok? (Pics)
TPMS is not compatible with my aftermarket wheels. The valvestem comes out from the middle of the hub and it turns 90 deg out. I've been looking at the TPMS and if I install it in place of the 90 deg valvestem, it looks that it can work.
One of the issue is how would I fill it with air being that it's in the middle of the hub? I went to the gas station and since the air nozzle is a flexible rubber hose, I'll be able to bend it and still fill the tire with air.
Will the TPMS valvestem clear the caliper? Yes, I measured and there is plenty of room.
The only concern I have is the TPMS will be perpendicular to the hub. It is designed to go on an angle so the sensor will be flat on the hub. In my case, it will be perpendicular to the hub so the sensor will be sticking out about .5" beyond the protection of the lips of the rim. Since the tires are low profile (235/35/19 and 275/30/19), I'm concerned the sensors might be crushed when I hit a bump. Or do you guys think there is enough space for protection?
This is the aftermarket valvestem.
![](http://i126.photobucket.com/albums/p93/Flipsonic/valve001.jpg)
TPMS
TPMS
![](http://i126.photobucket.com/albums/p93/Flipsonic/valve009.jpg)
Yes, I read all the posts and I thought about putting them in the spare tire, wheel barrow tire, or make a cannister out of PVC pipes (Sanwong's thread). I even thought about strapping them to the wheels. However I want a working TPMS that will stay on the wheels. Just wanted to see if what I want to do will work without damaging the TPMS. I guess people just don't want to chance it huh?
After some serious thoughts, I will just go with the cannister. My main concern is if I get a flat while on the road, the sensor will be crushed. So thanks for all the replies.
I have been driving for many years without a TPMS and never had a problem, even with low profile tires etc.
its just vigilance that is nessacary for making sure your tire preasure is right. Check it weekly, or monthly. But i dont need a sensor to tell me my preasure is low.
I tried strapping the sensor to the wheel, but the problem is the sensor is not flat, it as you can see is an odd shape, thus making it hard for the metal band to hold it in place.
the canister was the way to go, its inexpensive and the idiot light is not on.
until they can make the multipeice wheel TPMS compatiable (i have lexions too) the canister is the way to go, its temporary until someone can create a better idea.
that is just me......
BTW, i perfected the size of the cansiter, its now smaller then a 1liter soda bottle and is nicely hidden.
Unfortunately, drilling a hole will not work as the design of the wheel will not allow it. It is flat from the outer lip until almost to the other side. There is a spot well inside the rim but I would have to remove the tire and look if it's possible. I'll just leave that for another day.
Tech Info Resource
So while I'm avoiding the tire (it would have SERIOUSLY damaged my front end at 75 mph), checking my mirror to be sure I wouldn't get hit from behind, and scanning for additional hazards, I see a Ford pickup in lane 3 with the front left tire completely gone. Doubtless the driver was totally unaware the tire was flat until the sidewalls shredded and the tread lauched across the freeway.
So, I'm a total advocate of on-board tire pressure monitoring systems. It was sheer luck I wasn't 10 feet further down the road - had I been, I would be posting about how I lost my front bumper to someone's stupidity.
I am facing the SAME battle, I don't know what to do...do you just put all 4 TPMS sensors in b/w the spare tire and wheel loose? I guess the thought is that you simply don't ever use the spare as all four would be loose in there...??? Unless of course you band all four into the spare... Am I missing something here guys?
Peter
Peter
