Those of you with subwoofer issues
Hey I know a few of you including myself have been having some issues with aftermarket amps and subwoofers hooked up to the stock face. In another post I wrote that my installer talked to JL audio and discovered had created a new product that could help are situation and would first be seen at CES. My installer just called me and let me know that JL posted the specs of the product on their website
Here is a link for a first look
http://mobile.jlaudio.com/jlaudio_pages.php?page_id=217
Looks like this product should help solve most of the issues created by the stock head unit w/o having to install a complete clean sweep or something similar. This product should eliminate the bass defeat created by the head unit as well as an overall bass control. Although the JL rep said this product won’t be available until April or may can't wait to get this in my car
Yes! I remember your post kj... BUT, from a quick read of the url you gave, I don't see how this product will eliminate the "bass defeat created by the head unit" (I assume you mean the 30-80hz filter from the amp?)
I agree, however I am not an expert, what my installer and the JL rep have said is that the products ability to amplify the signal levels eliminates anychanges made but the head unit to protect the stock sub. Additionally the amount of bass can be controled from 0 to +10db by the ****. It may not be perfect but its by far better than what i have now, and probably the most cost effective solution. I have a JL amp so the products should work very welll together
Assuming that you got the signal by tapping into the stock subwoofer speaker wires, then you are only getting 30-80hz... I want to get 15-120hz to my sub...
It's just a pre-amp volume level control. These have been out for years if you knew where to look. I had one in my car audio system made by Sony that did the same exact thing over 10 years ago.
What it will do in a 2IS system:
1. Give you two RCA outputs (one with a wired remote volume control) to go to two aftermarket amps.
2. It will give you a remote bass level control if your aftermarket amp does not have one.
What it won't do in a 2IS system:
1. Convert the subwoofer speaker level output of the factory amp to RCA line level. It has only one RCA input and two RCA outputs.
2. Correct the 30 Hz subsonic bass filter in the amp because it has no onboard equalizer.
I'm a JL Audio fan. I have used their equipment before and probably will again in the future. They make some of the best quality equipment on the market. However this is not the "holly grail" product for us 2IS owners have been hoping for.
MJHSC400
47
05-04-07 10:33 PM
StereoGuy
02-03-05 11:46 AM
