Oil Maintenance Warning Light
Old 01-13-07, 06:35 PM
isdsms
isdsms's Avatar
Default Oil Maintenance Warning Light
I recently changed my oil and now the oil maintenance light has come on. It has probaly already been posted, but how do i clear it off?
Old 01-13-07, 08:55 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,066 Likes on 2,463 Posts
Check the FAQs, there is a link there with the whole procedure. It's pretty straight forward.
Old 01-13-07, 10:50 PM
Bichon
Super Moderator
Bichon's Avatar
It's also in the owners manual, and has been posted here dozens of times. A search for "maintenance light reset" is just one of many search keywords that would pull it up for you.
Old 01-14-07, 09:45 AM
warhummer
warhummer's Avatar
I don't think Bichon was lecturing, just pointing you to the search feature where you might be able to track down answers to your questions.
Does someone have a case of the Mondays?
Old 01-16-07, 02:09 PM
isdsms
isdsms's Avatar
Default Reset procedure not working
This is very strange! I press in the tripometer reset, hit the start button twice to get to the ignition on mode and the only thing that occurs is my tripometer resets. The oil maintenance reminder stays on. Does anyone have any idea what I must be doing wrong here? TIA!
Old 01-16-07, 03:09 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Use the button to show the odometer before shutting off. Shut off. Press and hold the button down. Press the start button twice. You'll see the dashes appear and disappear one at a time. When they are all gone, release and the odometer will appear.
Old 01-16-07, 03:19 PM
isdsms
isdsms's Avatar
Thanks, man! That was the trick...start at the odometer and not at the tripometer. All clear now! Thanks again!!
u7mg0
01-25-17 02:33 PM
rstrong
01-15-13 08:56 AM
ivey23
06-11-10 01:44 PM
p34m23
10-30-06 05:57 AM
BkLexZ
10-06-06 08:32 PM
Quick Reply: Oil Maintenance Warning Light
