What am I getting into? (maintainance)
#31
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
that's a false statement...
cars with performance tires will go thru the tires at the same rate (assuming its the same tire), quicker than all season, but nothing crazy.
#32
Highland Park raped me on a $1300 bill on my 92 LS.... The gave me a quote of $7000 when I brought in the car for a checkup.... Car has run flawless even though I didn't get anything that they "suggested." I still question whether or not I needed the power steering pump that was leaking, I didn't visually confirm that it was leaking, but oh well. Spilled milk.
Toyota did an oil change for me for $28 on my LS. Highland park wanted like $50, I think Bredeman wanted $45....
Haven't brought in the IS for an oil change yet though.
#33
I didn't make the comment specific to cars with performance tires, but to cars generally. I don't mind "paying to play", but if you don't find 15k tire life too be on the short side, you have a very limited frame of reference.
#35
It's not a false statement. Take a look at the wear rate of an average tire, and compare it to the 15-20k we got out of ours. That's called a higher rate of wear.
Continental ContiExtremeContact have a treadwear rating of 400 and cost $112 each for 225/40ZR18 and $166 each for 255/40ZR18.
#37
Tech Info Resource
I understand - but you make it sound like the IS specifically burns thru tires. BMW 3 series will go thru tires at the same rate, as will Mercedes C230, Audi A4 etc etc....once a set of tires need replacing, you CAN switch the tires to ones with a higher treadwear rating (these ratings are NOT accurate by the way).
What am I getting into? (maintainance) - I am thinking about getting the IS250 and kinda worried about how much is it going to cost me on the maintainance every month or after couple months how much it would be?
So the Lexus will cost more to maintain than a Camry/Accord/Grand AM etc., etc.. It will be cheaper than a BMW unless you purchase BMW's scheduled maintenance program, and about the same as the rest of the luxury class entry level sedans.
And the Continentals are second tier rubber, not first tier like the OEM Bridgestones. You might as well have included Falken, Riken, Kumho and others as they are even cheaper.
#38
So comparing to other class members is pointless. On an absolute scale, tires will be MUCH more expensive than the average compact sedan. Oil changes will be about the same depending on where you have them done, and brakes will also be much more expensive (based on Lexus's warning in the sales brochure - brake pads may last less than 20k miles and the rotors less than 50k miles). Air filters and such are all about the same, with the exception of the Lexus cabin air filter which are still found mostly in luxury cars, not in the cheaper models.
and that's 100% opinionated on the Continental tires....apparently Porsche/BMW/Mercedes think Continental tires are pretty good!
#39
you compared it to a Camry/Accord/Grand Am...I compared it to similar upscale cars...and in his initial post even the OP compared it to a 328 so I have no idea what you're talking about.
It's not a knock against the car, it's a fact. When I see people violently disagreeing with these types of basics, it makes me wonder if they have any sense of reality.
#40
Good grief. The point of my original response was to demonstrate that, relatively speaking, it is costly to own a Lexus IS. The car goes through tires rather quickly, brakes rather quickly, requires premium fuel, and is costly to maintain at the dealership comparatively. Drive a "regular guy" car for awhile, like a Camry, and you'll see the difference.
My S2000 went for 55K miles without needing a brake job done, and that was with spirited driving and a track day or two thrown in.
Bottom line is. You want a high performing sedan that will be reliable with average maint costs. The Lexus is your car. You want a high performing sedan with lower maint. costs get a new BMW(but only if you'll sell before the warranty is up). With the BMW you'll still go through Tires the same as any other rear wheel drive car. Sure the maintenance is "free" but you've already pre-paid for it in the extra cash you put down from the start....
Get yourself a Lexus and be happy. If true total cost to own is a concern, then a Camry or Accord is what you're looking for. But in terms of a sports sedan with rear wheel drive, you can't get much better than the Lexus.
