got a new headunit
#76
Cmusic,
I agree that the Alpine deck don't look right on the dash. Have you considered a custom glove box door to intergrate the monitor? It will give it the custom/integrated look. A new glove box door could be purchased if need to sell car.
Could you post some pictures of the LOC to Hub install?
#77
Once Alpine ships the new touchscreen monitor I will replace the current 5.8" monitor I have now with it. My Alpine dealer already has one ordered for me. I will also remove the Hub controller on the center console because the touchscreen will operate the whole system. I need the touchscreen to be within reach, which it is with the bracket the current screen is mounted to now. I could mould it into the glovebox door, but it would be too far over to reach easily.
I don't have any pictures of the LOC to Hub wiring because all you would see is two black boxes and wires. I used two David Navone NE-774V LOCs (one on the front mid/tweeter and front woofer, and two channels of the other one on the sub channels) coming from the factory amp and soldered each output wire (I cut off the RCA plugs on the LOC outputs) together down to two stereo wires. Those wires go into the Hub's stereo factory system input.
#79
I really loved the 7990 but I never did think it looked correct in the 2IS dash. Two months after I did the install Alpine released the VPA-B222 Vehicle Hub Pro that works with a factory audio system. I re-installed the factory head unit and placed the brain unit for the Hub under the passenger seat. I mounted a 5.8" LCD monitor on a cell phone bracket to be the display for the Hub. I mounted the Hub controller on the center console with double sided tape. I can control the whole audio system through the Hub.
Later this year Alpine is releasing a new touchcreen monitor that will take the place of the Hub controller on the center console and will replace the current LCD monitor.
Love the setup and I've been unsatisfied with all the alternatives I've tried so far to hookup XM and my iPod. Had Alpine equipment in my Jeep previously and loved the iPod integration and XM integration. Since I don't have Nav the OEM XM unit isn't attractive since it lacks so many features including basics like scrolling text and just plugging the iPod into the AUX port works but its not what I prefer.
#80
I’ve been doing car audio installs as a hobby for almost 17 years. To me installing the Hub was not too hard because I know Alpine products very well and did my electronic wiring homework on the 2IS before I started installing it. But I would rate it at a slightly difficult install for most shop experienced installers and very difficult if you have never done a car audio install or never did any 12V electronics work before. Like I said above in post #77 I used two David Navone LOCs to convert the factory amp wires to the Hub.
The Hub is compatible with Ipods with a single wire. The Alpine interface sounds great but is slightly more difficult to operate than the Ipod wheel. My biggest complaints are when I am at a song I can’t back out of the menu system to find another artist, album, or playlist quickly. I have to start at the beginning of the search function each time I change to a different “file folder”. The Alpine unit also does not allow fast scrolling through long lists to get quickly to another artist, song, or playlist. Hopefully the new touchcreen will allow me to do these two things easier.
As stated before, with an extra module, the Hub has full XM radio functions.
The biggest thing I like about the Hub is it is an independent audio source controller separate of the factory audio system. When playing anything except for the factory CD changer, I leave the factory system turned off. I can switch in and out audio processors, amplifiers, and speakers at will. Like I stated before, I love the Alpine 7990 CD player that headed up the system in my last car, but with the flexibility and multiple functions the Hub gives me, I actually like it better. And except for the monitor on the dash I get to keep the factory look.
#81
Which sound better? Audiocontrol LC8 or NE-774V? NE-774 does not have a summing function so the signal is still being x-over to the hub. Not full range, right?
If I use a JL summing box and Cleansweep. The output signal from Cleansweep is full range 20Hz-20KHz. Which is ideal just like a aftermarket deck's pre-outs.
LC8 is not full range 20Hz-20KHz. Just summed to F/R 4ch then to aftermarket amp.
#82
#87
so basically all your stock functions work? i know you said that your steering wheel functions work but how does all the audio functions work?
Does your stock deck have to be on in order for your Eclipse deck to work? Can your Eclipse deck work by itself or if your Eclipse deck is off could your stock deck work by itself (like stock)?
hapaboy
05-16-09 11:18 AM
spaniola
03-17-05 09:17 AM
