First oil change at 730 miles. My parents think I'm crazy.
Old 01-21-07, 06:27 PM
  #46
Koz
Koz's Avatar
Originally Posted by Gernby
There abosolutely is "break-in oil" for EVERY engine. The oil itself may or may not be anything different from regular oil, but every engine gets broken in with oil in it, right? Hence ... "break-in oil" = whatever oil the engine was broken in with.
Semantics.
Koz
Old 01-21-07, 06:56 PM
  #47
cvex
cvex's Avatar
Back in the days when I used to build engines, I've learned that to get everything in the motor to seat properly we use oil with very little or no detergent at all to break-in the motor. Which are most of the time the cheapest oil at the store, around less than a buck a quart. The results are excellent everytime we disassemble the motor again.
However, "IF" manufactors use these kind(detergentless) oil and switching it out early is just delaying the break-in process.
My 01' IS300 at 33k miles still has metal shavings in the oil . I dont if this is normal for Toyota motors but I got scared and traded that car in a while back.I bought it used at 30k miles
Old 01-22-07, 03:40 AM
  #48
Big Andy
Big Andy's Avatar
Originally Posted by Technique
10,000 km or 10,000 miles?
10,000 miles - 15,000 km in Europe.
If I might make one further point about the oil filters containing small metallic particles - that's their job! I'd be more concerned if I opened up the filter and found it clean as a whistle, that would suggest to me that it wasn't catching anything. The very fact that the metal particles are in the filter means that they are aren't in the oil, and once in the filter they aren't going anywhere. Change it by all means but after a few thousand miles a filter with small particles in it is just as effective as a new one.
Old 02-15-07, 07:38 AM
  #49
Technique
Technique's Avatar
https://www.clublexus.com/forums/sho...=1#post2425929
Here's the result of not changing the oil in my Jaguar for 3 years... The oil was just fine...
Old 02-15-07, 07:44 AM
  #50
gsrthomas
gsrthomas's Avatar
I think you lease your cars. If I leased I would stick to the factory recommendations also.
Since I bought it, I like changing the oil more frequently just to make me feel better and add alittle insurance. I normally keep all my cars near or past the 200k mile mark. So i'll just stick to my od habits.
All this previous talk about sludge issues in some of the past Toyota engines. Sometimes manufactures arent correct with their intervals. Sooner is better in my book, especially since oil is cheap.
Old 02-15-07, 09:19 AM
  #51
kickin8
2IS/2RX/4RX
kickin8's Avatar
Originally Posted by gsrthomas
Well.. Some guy in the 3rd Gen GS350 forum changed his oil at 500 miles and posted pictures of his oil filter and it had huge shavings of metal stuck in there and the oil was kinda glittery with metal in there. Here is his thread http://sr1.clublexus.com/forums/showthread.php?t=257889
So that thread got me scared and I changed my oil today on my 07 IS250 at 730 miles.
Plus the factory overfilled the oil by over half an inch above the full mark on the oil dipstick. So I didnt wanna run a new engine with way to much oil then its suppose to be in there.
So those two things prompted me to change my oil alittle early.
I did not find any huge pieces of metal though.
isn't that what the OIL FILTER is for ???????
i would not worry too much about changing the oil too early as some of the cars has addictives in their oil for break-in purposes (I know honda did add some stuff for new cars and they would not recommend you to change oil anytime sooner than 5000 miles)........
Old 02-15-07, 09:35 AM
  #52
houstonT
houstonT's Avatar
I too am overly **** and after 2 weeks and 1,100 miles I'm getting mine changed.
Peter
SQLnovice
03-30-17 04:24 PM
garygve
RX - 3rd Gen (2010-2015)
19
08-05-14 07:54 PM
javyLSU
08-19-11 06:51 PM
stech
05-27-08 05:55 PM
mxh3901
02-15-07 07:37 AM
Quick Reply: First oil change at 730 miles. My parents think I'm crazy.
