I'm stuck in the middle of installation!!
I'm installing my K&N intake right now. After I loosen the intake tube hose clamp at the throttle body and unclamp the clamps at the air box, do I just pull the tube out of the engine body? It was very tight when I tried to pull it off the engine. Everything is detached but the tube. Maybe it's just b/c of the cold weather. Little help would be very appreciated!!!!
Here try this thread. . . https://www.clublexus.com/forums/sho...d.php?t=234688
My homie javyLSU did the post hope it helps. . .
i just did mine tonite... you just got to give it a real good pull. youll be okay... the throttle body is metal so i mean you can only pull and cause damage to the rubber tubing which youre replacing anyways so just yank her out!
