Low tire??
Low tire??
Hello
My low tire signal is like on and off all the time. It's on whenever the temperatue is low outside (cold weather). What should I do to handle this?
I had the same thing happen. when it gets cold the air compresses or whatever. I just filled up my tires at the warmest part of the day so they wouldn't expand too much if it got too warm.. if that makes sense to you. then the little alert will go away.
I guess i just hate it since the alert is kinda sensitive..or i guess that's one luxury feature. It was on one day and the it's off when the weather turned warm that's why I am trying to find the best way to handle this. Thanks!!
It sounds like at least one of your tires is low on air, and the pressure fluxuation from hot to cold during the day is enough to cause the message. You should fill all of your tires up to the recommended pressure in your garage (about average temp without the offset of sunlight), and re-initialize the TPMS system (button to the left of the steering wheel).
My guess is that your pressures are probably in the very low 30 range when it is warm, and in the high 20s when it's cold. That would cause the behavior you are speaking of. If the pressures were up to spec (35-37 PSI), you wouldn't be getting any warnings.
Super Moderator
Have you checked the air in your tires with a gauge? The cold inflation pressure should match what is on the door jamb: 35/37. My guess is that you are a few pounds low, and the cold temps are enough to put you under the threshold to light the light.
Liquid Bra Champion
Liquid Bra Champion
Have you actually tried it,...I mean it's only twenty bucks, give it a shot and if you don't see a benefit come back and tell us.
