In Car camera mount options?
So I'm going to "The Dragon" with the S2000 crowd in april but since I sold my S I'm bringing the IS. I want to film the car going through the twisties, but does anyone have any ideas for an in car camera mount? That isn't too pricey?
I'd also like the same option for the occasional auto cross and track day.
In case you don't know what the dragon is. Here it is.
http://www.tailofthedragon.com/maps_dragon_road.html
That's not too shabby of an idea.... I wonder about picture quality though. Also not sure I want my laptop around the cabin flying back and forth. When you close it it goes into sleep mode. I've got a macbook with built in isight too, but don't think I'd want to mount that on the dash.
Yeah I've thought about just putting my normal tripod around the tunnel in the back seat, and then securing the tripod to the rear doors somehow, not sure how effective that would be though.
I've seen a mount that clips onto the headrest but can't find it. The other option would be a sticky pod where I actually have the camera on the outside of the car, suction cupped on.
there are also some other mounts. most common is some suction cups and you can mount those anywhere on the exterior. or a window clamp.
The camera mount doesn't have enough play to allow the camera to touch the bumper. I just purchased a cheap tripod from Walmart, and bolted the top to the factory tow ring. Removing the tow ring cover from the bumper isn't very hard with a flat head screw driver wrapped in electrical tape.
I considered a suction cup, but they are much more expensive, and I don't feel very warm and fuzzy about them. If the mount looses suction, the camera is destroyed. Also, if the suction cup and paint isn't perfectly clean, it can scratch the paint.
Gernby, nice setup you got there. But I suggest you put on some kind of protection for the camera's lens like a UV filter or something similar (if it even exists for your camera). Being close to the ground, I think it's susceptible to rocks, etc. and at high speeds it could definitely shatter the front element. Something to think about.
Here is an old video from an autocross when I had my S2000. The surface is so bumpy, that my alignment got screwed up at EVERY event. I eventually just quit going to events at that location. BTW, this was an FTD run.
Below is the mount I used for my S2000. It was a little more versatile since I used a longer threaded rod, and it would work on the front and back bumpers. The OEM tow ring isn't quite long enough to use on the back of the IS.
