Tire valve broke, need help
Old 01-20-07, 04:01 PM
maz
maz's Avatar
Default Tire valve broke, need help
I was checking my tire pressure, and after I closed it with a wrench to make sure its tight and no one steals the valve screw for their bike or anything like that. Well I tightened it too much and the valve stem broke in half and all the air came out of the tire. Now one half of the valve stem stem is stuck in the tire cap screw. How can I fix this ASAP?!
Old 01-20-07, 04:17 PM
15951's Avatar
Originally Posted by maz
I was checking my tire pressure, and after I closed it with a ranch to make sure its tight and no one steals the valve screw for their bike or anything like that. Well I tightened it too much and the valve stem broke in half and all the air came out of the tire. Now one half of the valve stem stem is stuck in the tire cap screw. How can I fix this ASAP?!
Uh...put the spare on, and take your flat tire in to the dealer to get a new valve stem installed. There's no quick fix for this.
Old 01-20-07, 04:22 PM
Cleric
Cleric's Avatar
Oh bummer dude! You may need to order a new sensor since the valve stem is part of the sensor. The part number is 42607-30030 for the sensor and 04423-35020 for the fitting kit (gasket).
Old 01-20-07, 05:41 PM
maz
maz's Avatar
Is it possible to just replace the metal part without replacing the sensor. How much will a single new sensor cost? I took it to the tire shop and they said I need to take it to the dealer cause of the sensor.
Old 01-20-07, 06:24 PM
Cleric
Cleric's Avatar
I would email lexus.parts.com with the part number i gave you and ask. It should be less than $100, which is much cheaper than at the dealer.
Physically you may be able to just replace the metal stem but since there is no separate part number for just that part, it looks like you will have to replace the sensor.
Old 01-20-07, 06:41 PM
TimboIS
Liquid Bra Champion
TimboIS's Avatar
after I closed it with a ranch...
LOL, you should have used a wrench!
Old 01-20-07, 06:48 PM
maz
maz's Avatar
Thanks I took your advice and emailed them. I will also see if the dealer can replace it under warranty.
Old 01-20-07, 06:49 PM
maz
maz's Avatar
Yea thats what I meant, wrench. I was in a hurry when I wrote that.
Old 01-21-07, 01:40 PM
CWS
CWS's Avatar
Of course, you know this now, but wouldn't it be cheaper to buy a few dozen cap covers, to replace any stolen ones, instead of using a wrench?
Old 01-21-07, 02:04 PM
kilo6_one
kilo6_one's Avatar
sensor and stem are the same, so you need to replace the whole unit.......
Old 01-21-07, 02:45 PM
XKronite
XKronite's Avatar
Wink Wth
A wrench ? What were U thinking my man?
You can't make this stuff up...
Do you also use jet fuel instead of premium ???
LMAO Literally ROTHF
Good luck dude ...
Old 01-21-07, 04:40 PM
SkyIS
SkyIS's Avatar
It is not worthy. My IS lost two of those four caps once. When I take it in for the 5K service, they put two new one on. That's without me requesting for them.
Old 01-21-07, 04:59 PM
lifeisgood
lifeisgood's Avatar
Sorry to hear about your misfortune. After four of my valve covers were stolen, I tightened mine with a wrench too, but was careful not to do it too tightly. Now I know what happens when too much torque is applied. Good luck.
Old 01-21-07, 06:29 PM
maz
maz's Avatar
I'm glad you learned from my experience. I actually learned to use a wrench to tighten them from these forums. Guess it's not such a good idea.
Old 01-22-07, 10:22 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,052 Likes on 2,455 Posts
It's a fine idea as long as you don't overtighten them. I would not apply more torque than I could apply with a screwdriver (40 - 60 in-lbs). If you put a 10mm socket on a 3/8 drive ratchet, yes, you will easily break the stem off.
It's an unfortunately expensive lesson.
Quick Reply: Tire valve broke, need help
