View Poll Results: are you running synthetic or a synthetic blend?
full synthetic
238
59.95%
synthetic blend
19
4.79%
dinosaur oil
39
9.82%
whatever the dealer fills it with
101
25.44%
Voters: 397. You may not vote on this poll
how many are running full sythetic or a synthetic blend?
Old 01-24-07, 01:20 PM
KOOLFELLA
KOOLFELLA's Avatar
Been running mobil 1 full Synthetic since birth, 12,731 miles ago. . .
Old 01-24-07, 01:37 PM
Batmobile
Batmobile's Avatar
Originally Posted by IS_Mine
6.7 quarts of 5w-20.
wow... learn something new everyday...
planning to take my car to the dealership at 5,000 miles for the first oil change... and free check up... after that.. planning to go to my local shop and putting in nothing but full synthetic....
not to be threadjacking but... i hear pennz oil's good too... compared to mobil one? how do you guys feel about it?
Old 01-24-07, 02:05 PM
Lexustom
Lexustom's Avatar
Just back from a dealer oil change. Too lazy this time to do it myself. I asked, "What are you going to put in"? They said "Castrol 10-30". Fine with me. I think.
Old 01-24-07, 02:10 PM
IS_Mine
IS_Mine's Avatar
I'm not an oil expert but 10-30?
Wouldn't that be bad? Isn't that lower grade of oil?
Old 01-24-07, 02:22 PM
cvex
cvex's Avatar
Not a lower grade but different weight viscosity. Meaning its thicker at start-up than say 5-30 . 10-30 is good for places where its quite warm or summer use.
Old 01-24-07, 03:15 PM
Bakpack
Bakpack's Avatar
At 4000 miles I switched to 5/30 Royal Purple, I jack the car up on the left
side during the change to ensure that all oil is drained. After all the oil has
drained with the drain plug out, I pour 1/4 to 1/2 quart of 5/30 Mobil 1
synthetic in and let it drain to rinse any contaminents that may have
gathered around the oil pan drain hole. While thats draining I break the used
filter element apart fin by fin checking for any aluminium fragments.
Then I button him up and fill him with 7 1/2 qts of Royal purple.
Old 01-24-07, 03:19 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,998 Likes on 2,422 Posts
Some people have been having issues with the hydraulic valve lash adjusters not pumping up quickly and hearing a clattering sound on initial start up. Let us know if you start having that issue.
My personal preference has always been 10w-30 synthetic since it needs no VI modifiers to meet the specs. No VI modifiers means the oil lasts inherently longer in service because you don't have long chain polymers getting cracked and the oil losing visocosity. Still, I'm following the recommendations during warranty for sure, so 5W-20 it is for now.
I'm sure Pennzoil is a decent oil, but Mobil 1 has been doing this for a very long time and I have a lot of experience with it (and Red Line) so I'm pretty much set on those two. RP and Amsoil also make excellent products, they're just harder to find in Wal Mart than Mobil 1.
Old 01-24-07, 03:24 PM
Gernby
Gernby's Avatar
Why use 5W-20 just because of the warranty? I seriously doubt Lexus could void a warranty claim because of using the oil recommended in the paper manual. I haven't received any notices in my mailbox from Lexus about the change, so I feel totally justified in using 10W-30 if I want to.
Old 01-24-07, 03:36 PM
Gernby
Gernby's Avatar
Bakpack,
It seems a little strange to use Mobil 1 to rinse out the last tiny bit of old Royal Purple when it will wind up leaving an equal amount of Mobil 1 in there. Mobil 1 will have different additives and detergents that may not mix as well with Royal Purple as a tiny amount of old Royal Purple.
It seems like a better practice would be to just drain the oil when it is at normal operating temperature for a longer period of time. If you REALLY want to rinse out the old oil, why not use Royal Purple?
Old 01-24-07, 03:43 PM
LexusNut13
LexusNut13's Avatar
Can someone please tell me what the main benefits to using a full synthetic oil are, and also if you start using full synthetic can you switch back or do you have to continue to use it from there on?
Old 01-24-07, 04:09 PM
Bakpack
Bakpack's Avatar
Originally Posted by Gernby
Bakpack,
I'm confident that all the Mobil 1 is drained and I used it mainly because it's
the only extra syn 5/30 that I had. After this most recent oil change I have
extra 1/2 qt of RP that I plan to use as a "final rinse" next change.
Old 01-24-07, 05:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
According to the manual, you'll have a quart of oil left in the engine after any draining. So no matter how you slice it, you're mixing oils. The rinse is only to make you feel good, it's not doing much for cleaning out anything.
Old 01-24-07, 05:51 PM
Gernby
Gernby's Avatar
I figured lobuxracer would have answered this. He's more qualified than I am, but I'll give my .02 about it.
Synthetic oil doesn't break down as quickly as conventional oil, so you don't have to change it as often. It is also supposed to handle high temps better, so it is better for "heavy duty" use. Even if you are a "regular Joe" driver, synthetic oil still makes financial sense because you can go twice as long between changes.
Old 01-24-07, 07:15 PM
Tony59blue
Tony59blue's Avatar
Mobile 1 full synthetic since the first oil change at 1000 miles.
Old 01-24-07, 07:22 PM
ddquach
ddquach's Avatar
I been running royal purple 5W30 and a synthetic additive as well (MOA)
Quick Reply: how many are running full sythetic or a synthetic blend?
