View Poll Results: are you running synthetic or a synthetic blend?
full synthetic
238
59.95%
synthetic blend
19
4.79%
dinosaur oil
39
9.82%
whatever the dealer fills it with
101
25.44%
Voters: 397. You may not vote on this poll
how many are running full sythetic or a synthetic blend?
Old 03-05-10, 09:53 PM
  #121
kg19989
kg19989's Avatar
Full synthetic of course!
Old 03-05-10, 10:35 PM
  #122
Kenji07250
Kenji07250's Avatar
Castrol Edge "advanced" synthetic
Old 03-06-10, 10:25 AM
  #123
IS-SV
IS-SV's Avatar
Originally Posted by i3urton
yea you have to change the filter every 5k miles
Is that necessary, running Mobil 1 at 10K intervals?
Old 04-19-13, 06:28 AM
  #124
reedenn
reedenn's Avatar
I'm having that valve tapping noise when i first started my gs350 in the morning. Oil change is due and will put a mobil1 full synthetic oil. Think this will help with the tapping sound?
Old 04-19-13, 06:30 AM
  #125
4TehNguyen
4TehNguyen's Avatar
just started using Mobil 1 5W30 synthetic. How long could I run it, I only drive about 8000 miles a year. I was thinking 9 months to a year
Old 04-23-13, 10:45 AM
  #126
Kurtz
Kurtz's Avatar
Depends what kind of driving that 8000 miles is.
If it's because you drive 2-3 miles a day every day, that's horrible for the oil (lots of short trips with no chance to run at operating temp)- in that case switch to the cheapest oil you can find and change every 3 months regardless of mileage.
If it's because you take one 50 mile drive 3/a week on the highway then once a year is just fine.
Old 04-23-13, 11:46 AM
  #127
4TehNguyen
4TehNguyen's Avatar
good 20 minute trip each way to work, about 9 miles each way, not stop and go
Old 04-23-13, 12:00 PM
  #128
Joshohoho
Joshohoho's Avatar
Im switching to mobil 1 5W-30 fully synthetic on my next change oil.
Old 04-23-13, 12:31 PM
  #129
bob4256
bob4256's Avatar
I recently started doing my own oil changes and have been using Royal Purple 5W-20.
Might try Amsoil next time
Old 04-23-13, 01:59 PM
  #130
Denver
Denver's Avatar
Mobil Full Syn..... regular/Syn Blend/Full Syn is like asking if you run 87/89/93 fuel but oil weight is a different story depending on weather and mileage of the vehicle
Old 04-29-13, 12:17 PM
  #131
intrinsic
intrinsic's Avatar
Anyone with higher mileage 100k+ notice the engine burns some oil? I noticed I have to put maybe .25-.5qt every now and then b/c my low oil light comes on around 4500mi. Haven't done it much, maybe twice since I've hit 95k. FYI spark plugs and engine top clean was done around 85-90k. But maybe I'm trippin out since I have driven to Tahoe about 6 times between my last oil change. Probably the high rpm's and hill climbs burned the oil? Maybe time to upgrade to syn since I've been only using regular oil every 5k?
Old 04-29-13, 12:20 PM
  #132
ls430lover
ls430lover's Avatar
everyone research mobil 1 extended performance oil and available at walmart 5 quart for 29
i have posted 20 threads its the best for the least money
cheers
Old 04-29-13, 12:30 PM
  #133
KINETICS
KINETICS's Avatar
I get my oil from walmart as posted above, $30 for a 5qt and $6 for the 1qt (2) bottles. Mobil1 Full Synthetic 0W-30 is what I put on mine. I believe it's better than the OEM 5W-30. Better for cold starts and short trips. I still change my oil every 5k miles regardless of driving style. The extra few $$ I believe is worth it when preserving the life of your engine.
+ OEM Filter
Old 04-29-13, 12:38 PM
  #134
minato
minato's Avatar
Mobil 1 synthetic 0w20 for cold starts , short /long trips ,summer, spring/ #dailydriven
I change between 6-7km
ajay60610
02-19-17 07:14 AM
krue92
IS F (2008-2014)
15
08-23-11 03:50 PM
schmoozer
15
04-18-10 10:47 AM
newgs3
10-07-09 07:34 AM
sjgIS350
02-05-06 07:53 AM
Quick Reply: how many are running full sythetic or a synthetic blend?
