GPS antenna location
does any one kno where the antenna is located. for the past couple of weeks ive been havin problems w my nav(being in a compleaty diffenrent state when im home or drivng in the ocean) im thinking it is the metalic tint in my back window but its been tinted since i got the car a year ago and worked fine untill a coulple of montha ago then worked again and now for about a month it hasnt worked at all.
Tech Info Resource
Slightly right of center in the dash just under the windshield (see below). There are a couple of threads about nav having this issue, and there is a TSB for the nav to correct it which updates the nav firmware but not the maps. There is also a map update with updated firmware, but you'll have to pay for it.
Super Moderator
Calibration should not be needed if your GPS is getting a lock. If it isn't, calibration will only be a temporary fix.
Look for the word "GPS" under the map scale indicator. If it doesn't appear within a few minutes of starting the car, then your nav is not getting a lock and is just using the steering angle and speed sensor to calculate position on the map.
gastric
02-11-08 02:41 PM
gs3_4me
04-17-01 05:58 AM
