Neo Prolink Ipod Integration kit for ISx50
Anyone bought and installed Neo Prolink? If you have, please post installation pictures !!
Looks very similar to VAIS, same features same price.
iPod Lexus Neo Prolink
2007 Lexus IS250 (PODLEXSLI) $299.99
website
The Neo ProLink iPod adapter directly connects to your radio, NO FM transmition or fuzzy sound! It gives you high quality audio, power and charging of the ipod as well as control on the radio and steering wheel (if equipped). If your radio supports text, you will be able to see text on the radio or navigation display. With the Neo ProLink for Lexus/Toyota you have two modes to use your ipod with your radio, Direct and Playlist modes. In Direct Mode you will be able to access and use the menu, click wheel, track and play/pause buttons from the iPod. You can change tracks on the ipod AND from the track buttons on your radio and steering wheel controls. In Playlist Mode you will have direct access to your top 99 playlists. You will be able to jump between them using the CD changer disc buttons.
How it connects:
The Neo ProLink kit includes a cable that plugs directly into your iPod. The cable on the other side of the kit plugs directly into your vehicles radio – there is no FM modulation. You get crystal clear, CD quality sound all while retaining the clean look of your factory stereo all with one simple cable that connects, controls and powers your iPod. It always keeps your iPod charged and ready to go. The Neo ProLink, replaces all previous adapters by adding more features, functionality, better sound quality and the ultimate in ipod to car performance and integration. This is the best iPod car adaptor kit available on the market using the highest quality components.
How it looks:
Features:
* Direct Connect - iPod plugs directly into the car radio.
* Power and Charging – Powers iPod and charges battery when iPod is not in use.
* Track Control – Change iPod songs from buttons on car radio.
* Steering Wheel Control – Buttons will control iPod (track, volume, etc)
* High Quality Audio – CD quality audio or better (depending on your audio files bitrate)
* Text – iPod text is displayed on factory radio (available on radios that support iPod text)
* iPod pauses when not in “iPod mode”, once car or radio is turned off, iPod will shut off and go into charge mode.
Use and Control:
Direct Mode - iPod Control on iPod:
* Direct use of iPod and control of every playlist, song, artist and menu setting.
* iPod screen, menu and wheel are NEVER locked out.
* Access and use of the menu, click wheel, track and play/pause buttons from the iPod.
* You can change tracks on the ipod AND from the track buttons on your radio and steering wheel controls.
* You will have access to your entire music collection from playlists, artists, albums, songs and genres.
Playlist Mode - iPod Control on Radio:
* Access to your top 99 playlists. You will be able to jump between them using the CD changer disc buttons.
* Text is displayed on all radio’s that support iPod text.
* Playlist, artist, and song info is shown
* In this mode your iPod screen, buttons and click wheel will be disabled, access to music is done directly from radio buttons.
You can seamlessly switch between modes by the press of a button, so you can try both modes and see which one you like or toggle between them at any time.
Additional Features:
With the Neo ProLink, we have added a 2nd device input to our adapters that is an auxiliary input. Now you can not only connect your iPod but also connect: CD, DVD, Mp3 players, aftermarket satellite radio, or any audio device in conjunction with the iPod. Switching between the iPod and the AUX input is done by the push of a button.
What iPods its compatible with:
The Neo ProLink is compatible with all iPods with a dock connector on the bottom. If you charge your iPod by plugging it in from the bottom, your iPod is compatible.
Important Notes:
* All factory options are compatible and retained (XM, RSE/DVD, external and internal CD changer). They will function as normal.
* Text display on 2006 and up vehicles. Vehicles prior to 2006 do not support text.
* Compatible with Navigation and Non-Navigation radio.
* Looking for a Cradle to add to your iPod Adapter? See our Neo Cradle part# CRADLEDOCKAV. The Cradle will dock your ipod and is mountable anywhere you prefer. Also has Video Out Capabilites.
website
How it connects:
How it looks:
Features:
Use and Control:
Important Notes:
Looks pretty cool, but One thing i love about my VAIS is it has the automatic "I Agree" bypass. I dont believe this has that and plus the VAIS has been tested that it works and it works great! Another thing is the price, if it cost the same as the VAIS, I would choose them because in case anything happens, it looks to be a company that wouldn't go Bankrupt in a few years..
not exactly the same as the VAIS since the VAIS doesn't have Direct Mode - iPod Control on iPod or multiple inputs (so you can connect a second ipod).
give it a shot, let us know how it works out.
inecstaz
10-05-07 08:05 PM
