View Poll Results: What viscosity oils are people using?
5w-20
15
38.46%
5w-30
21
53.85%
10w-30
0%
10w-40
0%
Oil? You cooking bish?
7.69%
Voters: 39. You may not vote on this poll
5W-20 is going to be like water in hot summer 100°F days-I may stick with 5W-30
Old 01-29-07, 10:26 AM
bagwell
bagwell's Avatar
Default 5W-20 is going to be like water in hot summer 100°F days-I may stick with 5W-30
I live in Houston and am a little concerned about using 5W-20 when its 100°F......what do you guys think???
is everyone switching to 5W-20?? regardless of where you live??
Old 01-29-07, 10:39 AM
Lexmex
Super Moderator
Lexmex's Avatar
Originally Posted by bagwell
I live in Houston and am a little concerned about using 5W-20 when it 100°F outisde......what do you guys think???
If you are worried about that, you may want to try to get your hands on some Castrol 0W30, this is that German Castrol. I am experimenting with it now, but no complaints thus far.
Old 01-29-07, 11:45 AM
linh811
linh811's Avatar
i have a crapload of mobile 1 5w-30. wally world had a sale so i stocked up.... gonna be using it for years, regardless of season...
The lexus will probably run 100k trouble free miles regardless of what oil you put in it...how long you plan on owning it??
I had a buddy that ran his RX for over 50K miles without a SINGLE oil change, then traded it in.... I'm not recommending it, just saying these things will run and run and probably get traded in long before any oil related problems come up.... no point in being so **** about maintenance....
Old 01-29-07, 12:23 PM
Koz
Koz's Avatar
A pure synthetic 5w-20 will provide better protection against thermal breakdown from heat then a 5w-30 petroleum based oil. Also 5w-20 dino oils have proven to provide excellent protection.
Koz
Old 01-29-07, 12:32 PM
Dj_AmtraX
Dj_AmtraX's Avatar
The car was tested in different conditions. I am sure Lexus would not use an oil that will damage the engine. Besides, if you use an unapproved weight, you may have a warranty issue if engine fails. Consider that before you change the weight.
Old 01-29-07, 02:08 PM
socalJD
socalJD's Avatar
Hell no. My oil cap says 5w-30, my owners manual says 5w-30, and the dealer used 5w-30 for my free 5k service. I heard that Lexus released a TSB on the oil update, but they never sent me a letter on it. I have a couple of cases of castrol GTX 5w-30 that I use for my 3.5l vtec Mdx, so that is what I'll use on the IS as well.
Old 01-29-07, 02:24 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,978 Likes on 2,406 Posts
You sound like you disbelieve the existence of the TSB. Right, wrong, or indifferent, it is what Lexus prescribe and fill at the factory. Here you go:
PNice972
PNice972's Avatar
5w-30 for me as well, didn't hear anything from lexus regarding oil
Old 01-29-07, 04:45 PM
jsquared
jsquared's Avatar
the TSB has been out for a while... that's what this forum is for, to get information that lexus fails to notify us about. i would think since a TSB is out, the dealer would notify you when you went in for an oil change. i haven't heard anyone getting letters about any TSB notice. for example, the low brake dust pads had a TSB, but they're not gonna send a letter out for every single one released. besides, it's not mandatory, just the new recommendation.
Old 01-29-07, 05:00 PM
bagwell
bagwell's Avatar
TSB is dated March 2006, so do all 2007's have 5W-20 on the oil fill cap????
Old 01-29-07, 05:13 PM
javyLSU
2IS OG
javyLSU's Avatar
What both the cap and the owner's manual say are irrelevant in this case - that's the whole point of issuing a TSB (which is NOT a recall, so you shouldn't be "expecting a letter" to alert you what the TSB says). The repair manual states:
Use the recommended grade specified on the oil filler cap or in the Repair Manual or Owner’s Manual for each vehicle.
In this type of situation, you would use the most recently published instruction, the Technical Service Bulletin (i.e. update to the repair manual), which specifies 5W-20 engine oil.
Javier
Old 01-29-07, 05:16 PM
Dj_AmtraX
Dj_AmtraX's Avatar
Many car manufactures have switched to 5W-20W. I have a 2006 Honda Civic which also use 5W-20W
I recommend that you visithttp://techinfo.lexus.com/ once a quarter to ensure you are up to date on TSB.
Old 01-29-07, 05:32 PM
accelerate
accelerate's Avatar
Yes if read the whole TSB it stats it is for better fuel mileage and emissions. This doesn't mean you have to use it.
Old 01-29-07, 05:36 PM
socalJD
socalJD's Avatar
Call me indifferent, we can agree that we disagree. 5w-20 oil is just a way for the manufacturers to squeeze more MPG from their vehicles to comply with CAFE, it started with Ford & Honda and now is catching on with others. Until Lexus/Toyota officially notifies ME that I must use 5w-20 in my 2006 2GR-FSE or risk voiding the factory warranty, then I will continue to use 5w-30, tree-huggers be darned . . .
Old 01-29-07, 05:41 PM
cvex
cvex's Avatar
Can you tell me whats the benefit over 5-20w?
Quick Reply: 5W-20 is going to be like water in hot summer 100°F days-I may stick with 5W-30
