new sensor, tire pressure monitor light on
I recently broke my old tire valve (see here: https://www.clublexus.com/forums/sho...d.php?t=260247) and had to purchase and install a new TPMS sensor. After inflating all 4 tires to the correct PSI, the TPMS light is on and the read-out says LOW PRESSURE. What needs to be done? Do I need to take it to the dealer and have them register the new sensor's serial number into the system?
And I already read the manual and it says that when a new sensor is installed, the system needs to be initialized with the satelite switch display set to Tire Initial and then holding the ON/OFF button for three seconds. I did this but the light is still on.
Okay, today I had the new sensor entered into the ECU by my dealer, and all was good, (no warnings or anything). As I'm going home from the dealer, about 5 miles into my trip, the tire light goes on again, the low tire pressure light blinks, and I see a "Check System" with a low tire pressure logo on top of it in the blue display area. Now what?
Marexus
01-12-12 06:15 AM
SACrx350
02-23-10 12:20 PM
