Wash to remove salt
Wash to remove salt
Here's the situation:
Temp outside: 5 degrees
Original car color: Black sapphire
Winter car color: Pearl white
The car is covered in salt. Here in Chicago, NaCl doesn't seem to be in shortage. What steps are you guys taking to remove this? The Lexus dealer won't even consider washing it since it's way below 32. I usually only use touchless washes, but this stuff is caked on the car.
DO NOT ATTEMPT TO WASH THE CAR!! Trust me even if you use hot water, by the time it drips to the floor it shouldve been frozen already, the only way is if you have a heated garage you can slowly wipe it off inside.
Hi Lupin, it's a machine wash but it's not a typical gas station kind. The car moves thru a 50-60 ft long tunnel on rail and you can watch it from inside the building through the glass. It's pretty awesome.
As the car exits the tunnel, it will be blown dried then hand-dried.
Sorry I forgot the name of the place..... It's at slightly to the west of Roselle on North side of Algonquin.
Don't powerwash it. It will surely freeze over your car.
I've got a great hand car wash I go to in Libertyville. Let me know if you want the details.
It's called Auto Expo and Detailing.
Uuuuuuhhhh.... NO! Do NOT try to wipe it off without soap and water. The guy has black onyx paint. Your suggestion is almost as bad as rubbing the car down with sandpaper.
You must be very young to think the old fashioned conveyor car wash that used to be the norm 30-50 years ago is 'awesome'. That's the way all automatic car washes used to be, before the gas stations figured out it was a moneymaker to wash cars, and the boutique 'hand wash' stands opened up. Unfortunately almost all of these conveyor systems use the revolving brush method of getting the crud off your car. I would never recommend putting a car through one of these. It is guaranteed to put marks on your car. Stay away. A conveyor belt system is cool for a Krispy Kreme doughnut, but not for a car wash.
If the car is caked in salt you need plenty of fresh, clean water to dissolve it and flush it away. A waterless type wash is just asking to scratch and scrape the surface. Just my opinion.
