Just got my IS350... but there is a problem
So I found an 06 IS350 used with about 17,000 miles on it. I basically bought the car because the ad said it had a Mark Levinson audio system which it apparently does not. I bought this car from a elite lexus dealer. Here are my questions:
1. Reading the book, it says there will be a ML logo on the front dash which i do not see anywhere. Does anyone have a picture of their dash with this logo?
2. What do you think my course of action should be? Should I call lexus corporate, ask them to install the ML system, or demand some type of money returned? I have had the car for about a month now and just noticed it as I haven't had much time to play with all the features. Thanks in advance!!
***EDIT AGAIN***
I have verified that I DO NOT have the ML system and I DEFINATELY wanted it.
*EDIT*
I should also mention I traded in a car and since it has been a month I'm sure it is probably gone.
***EDIT AGAIN***
*EDIT*
There should be a Mark Levinson Logo in the lower right hand corner of the unit. It is clearly marked. You can also tell if it is ML if you open the trunk and lift up the right hand plastic tray. The ML amp is under the tray and it will clearly be marked Mark Levinson.
If you absolutely need the ML system (and it's worth it) I would take it back and get my money back. If its not that important to you take it back and ask to be refunded the difference between the standard system and the ML system.
I don't think you are going to get much assistance from corporate, the transaction is between the elite dealer and you for a pre-owned car. The dealer has to make good, not Lexus corporate.
Good luck.
This is how it should look with the Mark Levinson.
Maybe the stack got replaced before?
http://www.marklevinsonlexus.com/overview.asp?model=is
Check here for some more info may help. Which dealer was this? Rallye?
Yup I sure do. I have the ad printed out which specifically states "MARK LEVINSON AUDIO AMAZING SOUND QUALITY" in 2 seperate locations. I would imagine if they didn't give it to me that it could be considered "bait and switch" or something to that effect which you can probably sue for.
If the ML logo isn't on the dash, or if there isn't a ML amp in the trunk, it's not a Mark Levinson system. It's easy to verify.
If you don't have it I'd take it back to the dealer and raise hell. Do not let them try to tell you all Lexus' have the ML system. Or that there really is no difference in the sound quality.
this sucks, you shouldn't have to double check what the dealer tells you about a car's options...BUT I usually research first and look at specific pics of the car to determine options and NEVER trust the dealers anymore -- a lot of them just have no clue.
does the car have NAV?
the best option at this point would be to have them refund the alleged Mark Levinson option price of the car which differs if it has NAV or not ($940 option without NAV, $1400 option WITH NAV).
in all honesty the dealer prob doesn't care it was labeled wrong and i cant see them caring enough to compensate you in any way either. if you dont buy it they will just re-run the ad w/out the ML part and sell it to someone else. id be surprised if they do anything for you. sucks but thats the reality of it.
Holy run on setence.. :P
Anyway, that would be like.. you buying an IS350, and they said the car at purchase had a V6.. you get it home and its an I4. Same principle.
I bought a 10 year old SC400 from Chicago McGrath dealer (no warranty purchased, though they offered to sell me one during transaction)... within 1 month the passenger brake caliper began to stick. By the time I noticed what was happening the caliper was getting hot. I went to my local brake guy who said the caliper was toast & so was the pad, rotor. I tried to contact the salesperson, but she did not return my call. Then I got the service manager.. he said to bring it in, but I was 40 + miles away.. anyway I didn't trust driving the car that far when within 5 miles the caliper was HOT!!! After paying the local guy $600 to replace the front brakes (2 new calipers, rotors, lifetime pads) I called the dealer and they were willing to send me $200 for my trouble. That was not satisfying to me so I called 1800-25LEXUS.... they apologized for the inconvenience & sent me another $100 credit voucher valid at any dealer.... and that was for a $12,000, 10-year old, 91,000 mile car...... you should definitely call them about your experience.
Frankly, Lexus' marketing of the ML system is so low key to be almost non existent. The only indication an owner has is a small logo on the deck. You would think Lexus would put some indication on the Nav screen when the audio system was in use to advertise it was a Mark Levinson system.
