Question about coilovers
I'm looking at getting the Tein CS coilovers. However, I talked to my friend, and he told me that coilovers will prematurely wear out the tires. He also said that the alignment will never be perfect with coilovers. Is this true? If it is, how fast do tires wear out? What about the alignment?
And I've always wondered what ride quality of the Tein CS coilovers are compared with the stock and the sport suspension. I vaguely recall that someone said that the stock suspension is like a 16 on the Tein CS, but I can't find that thread anymore. I'm just asking this because I may want a stiff ride now, but maybe later, I would want to soften the ride up back to the normal suspension. Thanks
Coilovers are designed as a complete shock/spring package targeted to provide race-car like handling which allows the car to retain more feedback from the road surfaces to the driver. So expect to feel every little imperfection on the road. If looks and handling are important to you, then go for it. If you want true real world handling on normal streets and the occassional winding country roads, the OEM or sports suspension package provides a pretty good balance between handling/ride comfort.
If not, just go with springs only which usually have lower springs rates of between 4.5 to 5.5 kg. However your OEM shocks will wear out a bit faster due to the higher spring rates. Its' suggested you change your OEM shocks at the same time but it seems right now there isn't too much aftermarket offering for just shocks upgrade.
good luck with your decision!
I haven't taken a ride in a IS with the CS but I have been in a G35 with the CS. At the lowest damper settings, they were softer than stock.
If you want the 'race car' experience with Teins, go with the SS or the Flex.
One thing you're forgetting is that the dampers play a crucial role in how soft/stiff, or harsh/floaty the car will ride. The CS are the least aggressive of the Tein line and at the softer damper settings, they should be somewhat close to stock.
Again, the "seat-of-the-pants" evaluation of how soft or stiff the ride in your friends' G35 is subjective. The difference between the OEM G35 to Tein CS softest setting might be insignificant, but the coilovers will still ride rougher. Remember coilovers are built for performance driving, not for looks alone.
If coilover is the choice, yes, the Tein CS is the best option that will be as close as OEM in terms of ride.
why would you get something to feel like stock for? if you jut want it to be lower save your $$ and get springs. me personally i think even the sport suspension is350 is still soft for a car like that. with performance like that it should ride a bit stiffer.
You're also forgetting that you can adjust the dampers on the coilovers to get a much stiffer ride if you wanted.
Stiff ride != better. Also, using compression damping to make up for lack of spring rate doesn't work well. Harsh ride is the only result, and poor wheel compliance means performance is worse, not better. Add in the short sidewalls on 18" and larger tires, and you have a recipe for wheels skipping over bumps and failing to properly follow the surface contours.
My chief complaint with Tein is their lack of adjustability. You get both compression and rebound changes in the increments they deem suitable. It is not possible to properly tune damping with compression and rebound tied together. Not only that, but you can only adjust low speed damping with their adjustments, and there are no options for the home mechanic to change any internal settings. Not very friendly for true performance tuning IMHO.
Finally, how are you gonna do REAL performance tuning without a shock dyno, which will run you back another $10k?
Real performance tuning? Lap times never lie. Besides, it's not rocket science to figure out when the tires are skipping over the tops of bumps on accel or decel. That's SOTP stuff I learned from tuning road race bikes.
Oh, almost forgot - go to Tein's website. They have charts showing the damping changes (oops - not anymore!). They (still) change compression and rebound with every click. Sad but true.
