Group Buy For HIDs
#31
I just wanted to say XD kits are the best out there. I have them on my IS for over a year and there were no single problem. I have 6000K kit and they looks so pretty!
#32
#33
I need some assistant over here.
I'm a second owner of the IS350. How can I find out whether my car has HID or not? My low beam light come in with a "ball" class that you see on most 2IS. I cannot see the actually light bulb itself as oppose to the high beam. Anyway, I'm curious whether that ball class is a HID or not.
Thanks in advance!
Thanks in advance!
#34
Thanks in advance!
Thanks in advance!
#36
#37
Its the autoleveling feature and the beam moves left or right on curvy roads for you to see the road better.
If you have a base IS350 then you don't have factory HID's.
To test this. At night set your headlight switch to "Auto", start the car and look at the headlight beam in front of you. If you see the beam autoleveling itself (the beam going down and up, and then stopping). That means you have the oem HID w/AFS.
#39
Thanks gsrthomas! I guess I don't have HID.
I can't believe that we spend almost 40k, just to find out that HID does not come in standard.
Here I come XD (Steve)...But, I'll have to find a place to install it first before I place an order.
#40
Where are you located Nuster? If you're in Socal,, you can get it install for 60 at alpha tint. He installed a few XD kits on 2nd IS already. His installtion is very clean. Hope this help
#41
Stig,
I remebered from your classified ads, you mentioned that you're from Berkeley. Where did you get your XD 6000K installed and how much was the installation?
Thanks!
#42
When you switch to HID, do you switch out your day/running lights too? doesnt it look strange with some blue/clear lights and some yellowish? can someone post pics of their lights? Also how much is the difference in brightness between the 4 and 6000k? sorry to ask so many questions but i'm thinking about switching to HID also.
#43
U cant really tell the DRL is there when you're HID is on. You can always change the DRL bulbs to White or blue, but that will defeat the purpose of DRL. I just received my Xtreme 3000k. I'll try to post some pic with my XD 6000k kit after i finish.
