Who has a Krzr, compatibility problem
Okay, did some research and this phone is suppose to work fine with the x50. I can make calls but receiving is a different story. My phone will ring but the car will ring once right before the call goes to voicemail and the call terminated message pops up on the screen. I tried everything, pairing and pairing. No luck. Does anyone else who has this phone have the same problem?
I have the Krzr (rogers - Canada). The only problem I have is, sometimes the # shows, and sometimes it doesn't.
I'm still trying to figure out if i can get the name to show.
Super Moderator
The number shows if you are standing still, but blanks out when the car is in motion.
The name shows up only if it is in the car's phonebook.
Figured out the problem
Okay, very strange, my ringtones is the purpose i can't receive a call through the car's bluetooth. I deleted the ringtones and it works fine. I even tried going through sprint store and buying a ringtone, tried it in the car and the same thing, no calls received. So I guess I will have to settle with the original ringtones if I want the phone to work well with the lexus bluetooth. I wonder if you guys have any ringtones and if it works properly.
COol, that makes sense now.. but still doesn't make sense on why the # won't show.
The names won't show on mine, even if it's in the phonebook. do you think it's digit sensitive? Cause I don't think i have 1 area code, where when my phone rings through, the 1 comes up.
Strange..
Super Moderator
Strange..
Strange..
I would assume the numbers (including the presence or absence of a "1") would have to match exactly.
Sleam
ES - 5th Gen (2007-2012)
07-20-07 10:06 AM
