On the IS, you will not be required to modify the vehicle in any way. The only part that will require slight modificaton is the OEM dust cover on the back of the headlight. You will need drill a hole in it to run the wires going from the bulb to the ballast and for the trigger wires.
Steve
I thought the HIDs are a plug n play?? Are you talking about the McCulloch kit?
The reason you need to modify the dust cover is because of the wire that runs from the bulb to the ballast. You need to drill a hole in the dust cover to run the wire through it.
Yeah the Xtreme kits currently on sale for the price is nearly identical to the McCulloch kits. From the Ballast, Ignitor, to Bulb. The only difference I see is the label.... Other then that... good ballast for the dollar.
