Will +38 offset for th rear rub?
I am thinking of getting Zenetti Fives in silver. Here are the specs I got from Zenetti.
19X8 +40 front
19.9.5 +38 rear
I have reviewed the thread on aftermarket wheels, but the people with +38 offset do not say if it rubs or not. I am lowered on Eibachs.
What do you guys think?
19X8 +40 front
19.9.5 +38 rear
I wanted to keep the rolling diameter the same for front and rear tires. I got used to doing it this way because I came from the Audi tuning scene where the quattro system has to be kept in sync from front to back. Now that you mention it, on a RWD car it does not matter much.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
you will have no problem with your set up. I have probably have the most aggressive drop with the tanabe suspension almost 2 inch drop all the way around running hre c20 19x8.5 38mm offset front on 235/35zr re750 bridgestone potenzas and same tire rear but on 19x9.5 offset 36mm running 275/30zr and it does not rub with trunk full and 4 peeps in car.... Doing aggressive mountain driving doesnt rub..... hope this helps....
06 graphite is350....
bentleymp2
11-21-12 07:54 AM
