DIY Front Brakes for IS350
#61
FWIW I have never had to use a factory scan tool to bleed an ABS system...
I also think that with most OEM brake systems, it'd be hard to figure out if there was a small amount of air in the system, due to the pedal feel changes introduced by vacuum brake boosters, rubber flex lines, etc. On a racecar, where you've designed the braking system and pedal effort from scratch, with no brake booster, braided stainless flex hoses, etc., its easy to tell if there is still air, because it yields a lower pedal effort than expected.
#62
Tech Info Resource
Yes, you do need the factory scan tool. RTFM. It's very clear you'll need to actuate the solenoid valves in the ABS if you get air in them, and there's no way to do this without the scan tool.
#63
If you do get air that is trapped in the valves that you can't get out by normal bleeding then yes you will need the scan tool to actuate the system, however I have never had the need to do this, and there are ways around using the scanner, I don't care what the effen manual says, just because it is writen in the manual doesn't make it 100 percent correct or mean that there isn't an alternative method. According to the manual the first step to starting your car is to apply the parking brake..yet the car will still start without the parking brake applied.....hhhmmmm
#66
Tech Info Resource
#67
quick question, the rotors slide right of after the two bolts are unscrewed on the calipers correct? and if im replacing the rotors are there any other little parts that need to be replaced other than the pads, I ordered drilled and slotted rottors from r1racing and green stuff pads. do i need to replace springs, schimes, etc.????????????
Weapon F
IS F (2008-2014)
53
05-05-18 06:38 PM
