Lightweight 17" wheel for IS350?
#47
Well I have some time to think about it, but you are right with all the numbers. That's why I have nicknamed you the "mad scientist" haha. Another ice storm is on the way this weekend, so hopefully things will be clear before March 3rd.
We got hit with about 4 inches of snow/ice a few weeks ago of which didn't start melting until this week. I hate this white stuff.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#48
Tech Info Resource
Rear Supra rims are 17 x 9.5. They'll fit pretty wide rubber without any issues. Offset is +50, and I have no doubt they would fit on the IS. If I get bored in the next couple of days I might test fit it. I have 265/40/17 SO-3s on mine right now, so it wouldn't be a bad test.
It is also possible to find used Supra wheels pretty cheap. You might also want to test fit the 16" wheels from the NA Supra. They're not so wide, but for drag racing, sidewall height is good. Short sidewalls (like 18's) are not nearly as good for a quick launch.
I also have a really good hook up for 5Zigen wheels. I've considered getting some FN01-RCs for exactly this purpose - very cheap (<$200 each), reasonably light (~18 lbs) and plenty strong for the IS.
Even a 3/4 view doesn't help much (of course the long shadows and brutal contrast aren't so great either, but hey, it's a snapshot, not a photograph!)
You can easily see here how the Supra tire is both wider and smaller - it will reduce the gearing and make the car quicker. Maybe a LOT quicker. We'll see Wednesday...
Now here's a view I do like...
Oh, I should probably mention, these wheels have 245/45/17 front and 265/40/17 rear. Both are one step wider but the same aspect ratio as the original tires sizes for a Supra. There are no issues with clearing the suspension, wheel well liners, or brakes. Wheels are 17 x 8 front and 17 x 9.5 rear both with a +50 offset. I think I'll just run the rears for Wednesday.
#49
You really think that size difference will make the car all that much quicker just because of the gearing change?
If so, maybe I would reconsider getting 19s... Man... you're making my decision between 18's and 19's very difficult, haha. I like the aesthetic appeal of 19s, but I really don't want to give up anything performance-wise. I figured a reduced weight of 3-5 lbs per rim would more than make up for the slightly larger diameter of the tire.
I've been unable to choose between these two sizes for months now...
#50
#54
Tech Info Resource
It's making the front end plow like a farm implement. It's jumping in very quickly and not at all as smoothly as it does with the stock tires. I'll keep the stock fronts on and just put the rears on for the drags on Wednesday.
#55
Tech Info Resource
Yeah, Wednesday at Sac Raceway is $15 grudge racing. Looking for good weather and maybe some quick times.
#56
Supra wheels are pretty heavy. About 26 lbs if I remember right. Still, I think the smaller diameter will help a lot. If I just had someone about 120 lbs to drive, I think I could make it into the 12's on gearing alone.
#57
Sorry for bringing back a long-dead threat, but I am curious how the tire and wheel exchange worked out for you all. Any improvements? Looking at Dragtimes.com I don't see any of you indicating the rear wheel swap
Thanks
Thanks
#59
caymandive, so how did it all go for the last few months? I've also been considering a pair of stock 18" OEM's to be wrapped with drag radials, and I would love to hear your thoughts.
1BADNSX
03-20-14 10:56 AM
