Low Tire Pressure Issue...
So about every two weeks I've been getting low tire pressure warnings and when I go to fill them with air its always 2 or 3 tires that are low.
This is unusual correct???
Should I bring this up with a dealership? I'm thinking about bringing it in tomorrow and getting it checked.
You think the tires would be covered or anything???
are your wheels chrome? sometimes the chrome dip has porosities that will always make your tires leak. if thats the case, there is little you can do unless you have a warranty on the wheels.
i had this same problem, i took it to the dealer one week they filled it and it went away, 3 days later same problem, i went back a week later and they said they had to reset the sensors and its been fine since then, my car has less than 2k miles on it so i know nothing was wrong with the tires, i dont drive over any crap so mabe you got the same problem i had
Super Moderator
In the 20s a couple weeks after refilling to 35 in front and 37 in the rear? Sounds like you definitely have a leak. If the source isn't obvious, a tire place (or the dealer) could use a soapy liquid to find and repair it.
