Problems with IS350
Problems with IS350
1. car pulling to the right
2. When sunroof is in tilt mode....it rattles
3. engine sounds like a diesel
4. AC stinks even after dealer spraying some sort of fragrance on cabin filter
Just felt like *****ing...I still love my car......
Car pulling -- tell the dealer!
Sunroof rattling -- tell the dealer!
Engine sound -- yea, those are the fancy stratified charge fuel injectors. You'll live.
AC -- do you leave it on full blast and turn the car off suddenly? these conditions can cause mold to form in the cold, dark, dry climates ...
I have a problem with my AC. I usually use "outside air" most of the time. But sometimes there is a bad smell coming in, I will use cabin air. But then the cabin air smells even worse! Do I need a new AC filter? I only have 4K miles on it...
Car pulling to the right mostly cus by tire allignment which u need to check. I'm having same problem cus I hit the pavment yesterday I really didnt see that curve there .. anyway I'm changing my rims so it dosnet matter
Cycle Savant
I can give advice on one thing...
Try turning your temp to the highest (85 degrees) with the fan at the highest speed, with the AC off, for about 10 minutes. You'll "kill" any funky smell out of the AC unit. It works for many of my cars' AC units.
Also, if you've had the car for a long time now, you may want to change the AC filter.
