removing stock sideskirts!????
i need help...im installnig a kit right now, and i need to know how to remove the stock side skirts...i took out all the pins at the bottom...the screws on each side...now i cant pull off the side skirts??? how do i get them off? even when i pull with all my force, they wont come off!!! am i sopost to angle it in a direction then pull??? all the clips and bolts are off...but they wont come off! i need the kit on by tommrow morning...help!
try this link from Sewell Lexus. it has the install instructions of putting the OEM side skirts, but it also shows you how to take off the side skirt. For some reason, the PDF comes out really blurry on my PC hope it is better for you
https://www.lexus-parts.com/partdeta...CategoryID=107
thanks for the info, i figured it out......for those who do it...you MUST remove the rubber part of the side skirts...just pull them out from the tabs...then there are 2 more screws behind it...once those are out, the whole side just comes off
