powering after market amp
Old 02-19-07 | 10:38 AM
khangaroo's Avatar
khangaroo
Default powering after market amp
Ok i've searched and searched and can't seem to find anything on this topic. Maybe I'm just retarded and everyone already knows this...but...
If I'm not mistaken the factory amp is in the trunk correct? If so, can I just split the power wire going to the factory amp and also power an aftermarket amp? This way there is no need to tear up the interior and run extra power wire to the trunk. All I'm looking to do is add a 10" sub to the factory system so the amp won't be more then 200watts i guess.
Old 02-19-07 | 11:23 AM
Dj_AmtraX's Avatar
Dj_AmtraX
If you want a fire in the trunk. You'll get lots of stares while BumpinG down the road. hahahaha....
Old 02-19-07 | 11:32 AM
cmusic's Avatar
cmusic
Ditto..
The factory power wire is 14 guage, just big enough to power the factory amp, and nothing else. The wire does have a 30 amp fuse under the hood, something that the factory amp and an aftermarket amp together would blow easily. Run an 8 guage wire with a 40-50 amp fuse next to the battery (before the wire goes through the firewall) to power a 200 watt aftermarket amp.
Old 02-19-07 | 11:54 AM
Dj_AmtraX's Avatar
Dj_AmtraX
Here is an amp wire calculator. I hope it helps. Sorry for the wise comment. I only said it because it happened to me when I first statred car audio install 13 years ago. hahaha.....
http://www.rockfordfosgate.com/rftec...calculator.asp
Old 02-19-07 | 12:06 PM
khangaroo's Avatar
khangaroo
Thanks good stuff...I knew i was probably suggesting something stupid...haha
Old 02-20-07 | 07:21 PM
Cleric's Avatar
Cleric
Originally Posted by cmusic
Ditto..
Sorry, don't mean to jack this thread but where on the firewall is there an available path for an 8 guage wire. Is there a rubber grommet covering a hole just below the battery on the Pa. side by chance?
Old 02-20-07 | 08:02 PM
cmusic's Avatar
cmusic
There is a 3" grommet just behind and to the left of the battery that a wire can be ran through. Most likely you will have to take the battery out. There is some factory wiring going through the center of the grommet, so be careful about punching a hole through the side. And remember to put a 30-40 amp fuse on the wire between the battery terminal and the grommet.
Old 03-05-07 | 10:42 AM
geez_yo's Avatar
geez_yo
Default grommet on is350 firewall pic
here's where you send the amp power cable through.
Old 03-05-07 | 09:05 PM
is_elf's Avatar
is_elf
I agree, I would not try to run power from your factory amp to your new amp. Just get it wired through should not be that much money.
Old 03-06-07 | 12:39 AM
AM1's Avatar
AM1
CL Folding 100000
i cant belive they run it with only 14 gauge wire. i was using 2 gauge in my old car for the subs and 8 gauge for my regular speakers.
andy2o3
05-31-13 02:46 PM
boogy886
07-28-10 07:44 AM
basketthis
06-03-10 10:03 PM
