View Poll Results: What kind of gas do you use?
91
547
41.66%
92
68
5.18%
93
612
46.61%
I'll put anything in there CHEAP!
86
6.55%
Voters: 1313. You may not vote on this poll
The mother of all 2IS gas discussions. Premium or Mid-grade (merged threads)
Old 04-11-01, 04:46 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,245 Likes on 1,363 Posts
Question The mother of all 2IS gas discussions. Premium or Mid-grade (merged threads)
This is the mother of all 2IS gas discussions.
Please post your "should I use only premium or can I use mid-grade or regular gas" questions here if you can't find the answers and opinions you seek from the posts already here.
I've merged several discussion threads on this exact topic together here & will add this to the FAQ.
Keep in mind some of the earlier posts are from just before the 2IS was formally released and specs known (such as compression, etc)
Old 06-30-05, 07:41 PM
Xanadu350
Xanadu350's Avatar
Default What Type Gas Expected for IS350
Since this will be a V6 engine, do you think it will take regular or premuim gas. Man, gas prices are still way up there & it's killing me.
I know my Lexus V8 baby uses only premuim gas. Since the new IS350 will have over 300 hp do you expect it to take premium?
Old 06-30-05, 07:43 PM
Gojirra99
Super Moderator
Gojirra99's Avatar
I think they'd recommend at least 91 Octane for the IS350.
Old 06-30-05, 08:07 PM
LawStudent
LawStudent's Avatar
With such a high compression ratio, I wouldn't be surprised if 91 Octane is required .
ncatona (05-21-21)
Old 06-30-05, 10:44 PM
Lextranny
Lextranny's Avatar
Anyone knows what the compression ration is gonna be?
Old 06-30-05, 10:58 PM
rominl
exclusive matchup
rominl's Avatar
i have no idea on the compression, but v6 with that much power, i think the compression would be pretty high
and definitely premium gas. i dont' think lexus will make the is350 able to use normal 87 gas
Old 07-01-05, 12:52 AM
CK6Speed
CK6Speed's Avatar
i believe the IS350 compression ratio is 11.8:1 and the IS250 will be a whopping 12.0:1. I'm pretty sure premium fuel will be required. In comparison, the Acura RL V6 with 300 HP is a 11.0:1 compression and requires premium fuel.
Old 07-01-05, 08:29 AM
CoreDump
CoreDump's Avatar
I think Lexus will definitely RECOMMEND 91 or higher octane. However, I do think running 87 will be possible but with degraded perfomance. It would be silly if people get stranded in some remote area just because premium fuel is not available . Just my two cents.
Old 07-01-05, 11:59 AM
CK6Speed
CK6Speed's Avatar
Yes, no doubt. As with most cars since the early 90s it will probably have knock sensors to retard timing when using lower octane gas.
Old 07-02-05, 11:47 PM
TSXtacy
TSXtacy's Avatar
most luxury brands recommend Premium (91 Octane). As some have said, with both engines using such high compression ratios, premium probably should be used. It's a pet peeve of mine when people don't put the recommended/required fuel in their car. I know a 1998 Audi A4 1.8T owner who puts 87 Octane in his car when 91 is pretty much the needed octane (it's a Turbo, I don't understand his logic!) Off Topic, but I figured I'd share.
Icetrai350 (01-27-20)
Old 07-03-05, 02:29 AM
xioix
xioix's Avatar
avalon requires 91, so the IS should aswell
Old 11-28-05, 10:32 AM
typo
typo's Avatar
Default gasoline
could have sworn i saw somewhere that the is250 uses regular gas, not premium. true? what's it say inside your gas tank access flap, new owners?
Old 11-28-05, 11:31 AM
MD727
MD727's Avatar
I only wish you were right - inside my is250 gas tank it clearly states that only Preimum Fuel be used.
Old 11-28-05, 02:31 PM
the lndr
the lndr's Avatar
He is right, I have used the middle grade when they are out of premium.
Old 11-28-05, 04:31 PM
mhiggi02
mhiggi02's Avatar
Ditto here.
Quick Reply: The mother of all 2IS gas discussions. Premium or Mid-grade (merged threads)
