The Oil in the car when they deliver...
When you purchase a Lexus IS 250 AWD, what kind of oil is in the car? I am just curious because I saw a thread with oil and stuff so I decided to post this. And is it better to get my own oil or should I just take it back to the lexus dealership and have them change it for me? (what kind of oil would they use?)
Unless it specifically stated somewhere in the engine compartment, or on the oil cap that they used synthetic then its most probably its regular motor oil. And the type/weight of oil they used is printed on the oil cap.
-Tommy
-Tommy
Maybe not. The cap might still say 5w-30, but the engine was factory filled with 5w-20 in Japan. There's no need to worry about it. Just drive the car and enjoy it. The oil used at the factory is perfectly good oil.
And about my prior question, should I buy my own oil or should I take it to the dealer every 5k miles?
According to Lexus, they changed their recommendation because 5W-20 provides better fuel economy and cold start performance. But 5W-30 is still a perfectly acceptable choice too.
Well said. Come on guys...lighten up on this oil issue. Do you think Lexus would fill your engine, or recommend an oil grade if they thought it was detrimental to your engine? Why second guess their engineers who have spent countless hours engineering the engine and its expected uses to ensure it performs to the expectations of its customers. Also remember that Lexus warrantees these engines for six years. Do you think for one moment that they will recommend something that will jeopardize the warrantee and cost them money and reputation? Give your head a shake and forget what the factory fill is and when changing oil, follow the Lexus recommendation...unless you are a lubrication engineer who has many years of experience in designing motor oils for automotive internal combustion engines. Lighten up!
Jimjaix, if you know how to do oil changes and/or have done them before, the oil change on the IS is not complicated at all. If you have the tools and it's convenient, save some money and do it yourself.
Javier
Javier
