Please help asap!! Question regarding IS 350 headliner.
Do you guys know if it is necessary to remove the front windshield to install a new headliner in a 2006 IS 350?
The dealer removed it to do some PDR in the roof and damaged it when putting in back together....
I will appreciate all you input. Thanks in advance.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
no you dont need to remove it to take out the headliner...BUT the headliner is fragile, like cardboard so if you bend it to get it out...you might leave a crease mark...they might of taken out the window to be on the safe side.
So, can you get the headliner thru the front doors without bending it? I will hate to break a factory seal.
