Front door closing sound
My 07 IS350 rear doors close with a muted expensive "thud" sound (Standing outside while closing). The front doors have a more metalic sound, as though something is loose. It is not quite a rattle and does not seem to come from the door mounted mirror. Tried the front doors on another IS and they sounded just like my rears.
Anyone have this condition? What is the fix? Thanks.
Anyone have this condition? What is the fix? Thanks.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Ok.. lol..
Just take it to dealer and they should fix it for free. If not, they will give you a nice story.
locate cause, it would be better to know for sure, especially if it is something simple that does not require door panel removal. Thanks for the response.
Will do.
I also noticed if I held the external handle in the open position and tried to close the door (of course it won't latch) it sounds just like the rear doors..nicr thud. Not sute if this means that the latch mechanism is the problem area. Guess that I will have to depend on the dealer to determine cause. Damn, just don't want those door panels pulled.
Thanks for your suggestion.
Will advise outcome.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Pulling this one up from the dead. A necro bump if you will.
I purchased a 2008 IS350 with 60k miles on it in November but haven't gotten to drive it much yet. I'm still getting used to it and figuring out all of it's rattles, quirks, nuances and etc.
One thing I've noticed is that the rear doors and passenger side front door all have a nice expensive sounding "thud" or "wump" when closing. However, my drivers side front door sounds thin and flimsy when it closes. Kind of like a hollow shell of a door. It's not hard to close at all though and it's just as easy as the other three.
My thought is that maybe the front driver side door sounds this way when closing because it gets used the most and wears out the door seal a lot faster than the other doors. Or the locking mechanism has moved a smidgen inward and is pulling the door in further to the body causing it to close harder and compress the door seal a lot more. I may pull the door panel off to see if it's missing anything like the plastic weather seal or maybe has been worked on in the past.
Any way, I was wondering if others have experienced this and what they did to remedy it. The car looks amazing but when closing this door it makes it sound like I'm driving a rusted out beater.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Rear are quieter than front, they give you a nice feedback as if they were new.
Front doors however ( specially the driver door) give a feedback as if it were slammed, and front doors feel lighter !.
I suspect it is related to one of the door seals but which one, who knows. Unless someone figured it out...
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Hmmm....I didn't look at the door hinge. I'll have to check that out this weekend. At a quick glance the door seems to be aligned properly but I will definitely double check more thoroughly when I have time. Thanks!
