Basic maintenance cost $$$ Here are the numbers...
Old 03-25-07, 01:34 PM
warrionex
warrionex's Avatar
Default Basic maintenance cost (Comparison with BMW)
when you first bought the IS250, bet some of you did not took into consideration the basic service cost for the car. These are the numbers for five years or 60 month service in my location (San Juan, Puerto Rico).
6 Months or 5,000 Miles - Free (cost $98.73)
12 Months or 10,000 Miles - $204
18 Months or 15,000 Miles - $445 + $190.95 = $635.95
24 Months or 20,000 Miles - $204
30 Months or 25,000 Miles - $204
36 Months or 30,000 Miles - $634.50 + $190.95 = $825.45
42 Months or 35,000 Miles - $204
54 Months or 45,000 Miles - $445 + $190.95 = $635.95
60 Months or 50,000 Miles - $204
Total aprox.= $3,117.35 Basic mantainance
FOR A COMPARISON WITH THE BMW'S SERVICE POLICY GO TO THE 15TH POST !!
FOR THE BENEFIT OF EVERYONE POST THE NUMBERS IN YOUR LOCATION
File Type: pdf
Old 03-25-07, 02:00 PM
bagwell
bagwell's Avatar
well for one -- the first service is free here in the continental U.S.
#2 the 10K mile service is basically just another oil change (as are most of the others), you can't rotate the tires, etc.
Old 03-25-07, 02:03 PM
warrionex
warrionex's Avatar
You're correct. I just double checked with them and it's free here also.
Old 03-25-07, 02:12 PM
lexudv
lexudv's Avatar
Don't have all the numbers, but since my car is approaching 15k miles I called Longo Lexus and they quoted me $226.14 with tax included. A regular oil change such as 5 and 10k is $54.00. This is not that bad compared to other prices i've heard, but I've done the first two oil changes myself and I think I can do this one as well.
The only thing that worries me a little about the 15k service is the recommended inspection list:
- nuts and bolts
- check oil level for differential oil
- Axle shafts and ball joints, etc...
Do any of you think this is a do or die, and if so can I do this myself? Do dealers even check for this when your bring it in ??
Old 03-25-07, 02:20 PM
bagwell
bagwell's Avatar
- nuts and bolts
its not do or die...
'INSPECT THE FOLLOWING' - means they just put it up on a lift and take a look at it. I don't visual inspections are mandatory for to keep your warranty in effect.
Old 03-25-07, 02:59 PM
joonsta
joonsta's Avatar
What about the 30 day service?
Is that free along with the 5,000 mile service?
Old 03-25-07, 04:00 PM
gsrthomas
gsrthomas's Avatar
When should the differencial oil be changed??
Old 03-25-07, 04:34 PM
kensteele
kensteele's Avatar
either prices have gone up and it's very expensive in pr: https://www.clublexus.com/forums/sho...d.php?t=240559
Old 03-25-07, 05:05 PM
JoesIS250
JoesIS250's Avatar
ill be going in for my 15000 mile service and all im asking for is an oil change and tire rotation ( awd version here ) other than that im not going to pay all that $$$$ for "visual" inspection or "peeking" at the items ??????
Old 03-25-07, 05:20 PM
Nuster
Nuster's Avatar
Joes,
For 15K service, you're suppose to change the engine and A/C air filters in addition to the regular oil change. Those two filters can be easily change by yourself. But, both filters will cost about $80 bucks.
I already changed both of the filters little bit after 11K because my car was 15 months old, but the mileage is low.
I think that's pretty much it for the 15K and maybe 30K service. The in-betweens are just regular oil changes.
Old 03-25-07, 05:33 PM
JoesIS250
JoesIS250's Avatar
thanks for the fyi. im not too mechancially inclined however changing filters i can handle
Old 03-25-07, 05:40 PM
warrionex
warrionex's Avatar
Originally Posted by Nuster
Joes,
This is the info available in the SCHEDULED MAINTENANCE LOG for the 15k service:
Attached Thumbnails Basic maintenance cost $$$ Here are the numbers...-15k-service.jpg
Old 03-25-07, 05:43 PM
warrionex
warrionex's Avatar
Whao !! What a difference!!!
5k $0
10k $144
15k $328
20k $144
25k $144
30k $442
35k $144
40k $144
45k $368
Total (incl tax): $1,945
Old 03-26-07, 01:49 AM
newr
newr's Avatar
If you had a BMW, the figure would have been $ZERO
Old 03-26-07, 02:48 AM
warrionex
warrionex's Avatar
You're mistaken, my only purpose with this thread was to compare the IS service figures with the BMW "free" maintenance policy for four years. I knew someone was going to bring up the BMWs FREE Service policy issue.
Let me show you that not only the BMW service is not free, but also the service cost with BMW is higher than with Lexus.
In my location, the base 328i sells for $42,995 and the base IS250 sells for 40K.
$42,995
$40,000
Dif: $2,995
328i = $2,995.00 (service cost for 4 years)
IS250 = $3,117.35 (service cost for 5 years)
Conclusion: The IS250 maintenance cost is lower than BMWs 328i. The $2,995 does not include the interest your are paying in the financing of the car.
Let's apply an interest rate of 5.54% APR (Penfed.com) to the cost difference of $2,998. The financing is for 5 years/60 months. You will end up paying $440.80 more for the maintenance and with the IS you have a whole year more of service for less money.
328i = $2,995.00 (4 year free service)+ $440.80 (5 years of interest) = $3,435.80
IS250 = $3,117.35 (5 year service cost)
Quick Reply: Basic maintenance cost $$$ Here are the numbers...
