HELP: HID's ECT.
HELP: HID's ECT.
Okay heres the deal, I want to purchase lights for my mirror's (blue), my fog lights (blue), my regular day time running lights (blue), and my high beams (really bright white). I need a list of the bulbs for this and yes i know there is a post with the info im just really confused so if someone can post a list of what i need that would help alot cause i want to purchase them quickly. Also are the regular running lights the same thing as "low beams"? Thanks for the help!
uhmmmm..
your regular day time running lights are also known as DRL. and they are the lights that come on as soon as you start your car. Since this bulb runs at a lower wattage, its gonna be hard to make them a blue color.
your low beams are the lights them come on when you twist your headlight switch twice. ( the lights you need to see in the dark).
your drl's are your highbeams giving out a lower wattage.. then theres the 194 bulb near your highbeams which comes on with your low beamss.. foglights are 9006 high beams 9005 low beams are D4S side mirrors are 194... google those bulbs...
9006 TWO for foglights
9005 TWO for Highbeams
194 TWO for your headlights (if you wanna change those to..)
194 TWO for the side mirrors
Interior.. 194 TWO for side doors.. 194 TWO for the lights for the head visor... 194 THREE for the front dome light.. TWO 31mm festoon bulbs for the rear dome lights.. ONE 31mm Festoon bulb for the trunk..
