20's and Tires
20's and Tires
So I have had my 20's on my 350 now for a while, and it also has the eibach pro kit on it. I had some serious issues with rubbing when they first got installed and until now the issues realy didn't go away, I just learned to ignore them. I had for a tire set up: Kumho Exsta Sports 225/35/zr20 for the front, and 255/35/zr20 for the rear. Well the tires wore out after approx 20k, and got a new set yesterday. I got the Toyo Proxies on the car now, and I got the same size as before, and what do you know....NO MORE RUBBING!!!
Just wanted to share that with everyone. I guess the brand of tire makes a gigantic difference.
That's GREAT! I got a little discouraged from your reply to my pm about the rubbing issue with 20's and that setup. But now I think I'll dive right into the DUB CLUB! Glad to hear your problems have gone away (with the rubbing)!
I actually got the Proxy 4's also. Thats great news about them. They seem a little bit looser than the Kuhmos were, but they might be over inflated right now. What pressure you have yours at?
i have mine at 38 PSI front and rear. ill admit they are somewhat noisy and they probably dont "stick" as well as other tires but they wear really well. i had the Toyo Proxies SUV tires on my 4Runner in 22" and i got well over 30k on them too, which is why i got them for the Lexus.
Stock Premium Wheel/Tire - 255/40R18
Section Width: 10.03 in
Rim Diameter: 18 in
Rim Width Range: 8.5 - 10 in
Overall Diameter: 26.03 in
Sidewall Height: 4.01 in
Radius: 13.01 in
Circumference: 81.77 in
Revs per Mile: 799
Actual Speed: 60 mph
Speedometer Difference: -
Diameter Difference: -
Your New Rear Tire - 255/35R20
Rim Diameter: 20 in
Overall Diameter: 27.02 in
Sidewall Height: 3.51 in
Radius: 13.51 in
Circumference: 84.88 in
Revs per Mile: 769.8
Speedometer display @ 60 mph: 57.8 mph actual speed
Speedometer Difference: 3.793% too slow
Diameter Difference: 3.67%
Your New Front Tire - 225/35R20
Section Width: 8.85 in
Rim Diameter: 20 in
Rim Width Range: 7.5 - 9 in
Overall Diameter: 26.20 in
Sidewall Height: 3.10 in
Radius: 13.10 in
Circumference: 82.30 in
Revs per Mile: 793.8
Speedometer display @ 60mph: 59.6 mph actual speed (if mounted on rear of car)
Speedometer Difference: 0.655% too slow
Diameter Difference: 0.65%
You can calculate tire sizes like this on 1010tires.com if anyone is interested.
I am stuck with 225/30/r20's and i am SO VERY anxious to get another set of tires on there (bought the vehicle with them on the car). i think i am going to have to take after you and get some of the exact same tires. i hope you don't mind
Rim Diameter: 18 in
Radius: 13.01 in
Revs per Mile: 799
Rim Diameter: 20 in
Radius: 13.51 in
Rim Diameter: 20 in
Radius: 13.10 in
AZDesertGS
Wheels, Tires & Brakes Forum
02-26-06 12:11 PM
