Remote Control - Make Windows Roll Back Up Hack?
Anyone know if there is a hack/fix out there to make the windows roll back up like the non US versions of our cars do with the remote control key fob? I searched but couldnt find anything...
There is a way to roll the windows back up using the key fob for US versions.
Follow these steps:
1. Remove the key from your fob
2. Remove the key hole cover from the driver side door
3. Insert key
4. Turn counter-clockwise and hold
Your windows should now roll up and sunroof will close.
Follow these steps:
3. Insert key
Damn it... So how are they doing it? Is it actual programming thats stopping us from fixing it or is a part perhaps that we can buy from another country?
Tech Info Resource
The solution to the problem is not immediately clear. The window controller is based in the driver's side switch assembly, so it might be that the driver's side switch could be replaced with an overseas unit and all would be good. Or it could be in the Body Electrical ECU. Since there are three networks on the car (CAN, BEAN, and A/V) and they've really leveraged this connectivity, it could be either (or neither) of those devices. The only way to tell for sure would be to acquire them from the foreign versions and see if it solves the issue.
Same thing with the remote start in the keyfob. Hmmm. We never did hear the results of that testing did we...
I know, wouldnt it be tight to be able to roll them down when you are walking up to it, and then roll em up while walking away after parking? Nice
For once Australia gets what you US don't.
1. push start button (foot off brake)
2. foot on brake
3. tap suroof dial
4. push start button (foot on brake)
5. push and hold display for 30-35 sec.
6. place fob over start button
7. open all windows at once
8. close all windows at once
and voila! not you have a eastern spec car.
pause
NOT!!
2. foot on brake
3. tap suroof dial
pause
NOT!!
You might be right... But I know my '03 accord could roll down the windows with the remote but wouldnt roll them back up and I really wanted that feature in that car too. I think they should just let us do it and work on making the anti-pinch sensing better or something. Maybe an IR sensor that looks for obstructions in the path of the whole window as is rolls up... I dont know.
Super Moderator
magne
05-21-15 10:22 AM
