ECU Computer Reset Today at 5K Service
Old 10-06-07, 07:51 AM
  #31
RU514
RU514's Avatar
I just did the ECU reset but I have a question. I pulled the right switches and I kept them out for about 2 min (I know how it said longer than a min so I just wanted to be safe). Then I put them in, waited about 15 secs, and turned the car on. To my amazement, it started on the first try. So did I even do it correctly? I know people have had problems not starting the first time around that's why. I know then people will say well how's the car driving differently. I haven't had the chance yet to test it but a quick drive around the block didn't seem to change it much.
Old 10-11-07, 11:32 PM
  #32
i3urton
i3urton's Avatar
Is resetting the ecu give you a better 1/4 time than useing power mode???? ive been getting better 1/4 useing snow mode....but better 0-60 time useing pwr mode.
Old 10-12-07, 12:00 AM
  #33
MPstyle
MPstyle's Avatar
I drive my car like I stole it, every time... only thing the ECU learned was to use A LOT of gas.
Old 10-12-07, 04:19 AM
  #34
caymandive
11 Second Club
caymandive's Avatar
No, if you reset the ECU right before a run, the car will run about 2/10ths slower as it's relearning. This was the case for me at my last track visit and I noticed the car even bounced off redline in second gear in auto pwr mode. The next run the car was back to normal.
Old 10-29-07, 03:44 PM
  #35
rfx45
rfx45's Avatar
I read the whole thread and did not find a direct answer. Before I try resetting the ECU I just want to make sure, is it required to disconnect the negative or positive wire of the battery before resetting the ECU or is it possible to reset it without disconnecting the battery at all? Thanks.
Old 10-29-07, 07:24 PM
  #36
GOBUCS
GOBUCS's Avatar
Resetting the ECU is Does NOT require disconnecting the battery, if you follow the guidelines on #2 by Lobuxracer or myself {GOBUCS**.
Old 10-29-07, 08:24 PM
  #37
italiandud
italiandud's Avatar
But if they reset the ecu, isnt it going to re adapt to the way you drive once again????????
Old 10-29-07, 08:35 PM
  #38
iialcii
iialcii's Avatar
will there be any difference for 6MT owners?
Old 10-29-07, 10:06 PM
  #39
rfx45
rfx45's Avatar
Thanks, I was going to follow the guideline #2 but the first thing it says to do is to disconnect the negative battery cable so I wasn't so sure if I should or not.
Old 08-11-08, 09:33 PM
  #40
Sytfu_IS
Sytfu_IS's Avatar
Just do this. It works.
how do you remove the efi and etc, their like stuck hard. What tool did you use to pull it out?
Old 08-11-08, 10:37 PM
  #41
kevintq
kevintq's Avatar
You use the fuse puller to pull those fuses out.. the fuse puller is that white thing labeled in the picture. =]
Old 09-06-08, 04:58 PM
  #42
IS350JDM
IS350JDM's Avatar
I just reset my ECU using this method, by pulling the 2 fuse. As expected, it didn't start up the first time, and worked just fine the second time.
I'm gonna drive it like I stole it for the next little while and hope the ECU can learn a more aggressive driving style.
Old 09-06-08, 05:36 PM
  #43
kevintq
kevintq's Avatar
so to clarify... wen doing this we DO NOT need to disconnect the battery wat so ever. All we need to do is just pull the fuses out for like a min or so...
Old 09-06-08, 07:43 PM
  #44
IS350JDM
IS350JDM's Avatar
Yessir! Exactamundo!
Old 09-07-08, 03:10 AM
  #45
tfz_hebe89
tfz_hebe89's Avatar
so what did you guys find out after resetting the ECU? smoother shifting? better acceleration? share your results please...
Quick Reply: ECU Computer Reset Today at 5K Service
