ECU Computer Reset Today at 5K Service
Old 01-02-19, 02:56 AM
  #61
Migeru
Migeru's Avatar
Default Would ECU RESET Fix Slow Acceleration??
This happened a couple months back. One night, as I was about to go home, I saw that it was raining quite heavily so I started the car then I had this brilliant idea to do some skids in the rain and since it was wet I thought it wouldn't put too much strain on the car since there's less grip so I shifted to first gear (Yes, its a Manual!) and stepped on it whipping the tail out, not knowing I had forgotten to turn off traction control I kept pushing it until the car gained traction again. After this "incident" I noticed that when floored the gas pedal the response of the throttle was weaker than usual, there's a slight delay when I accelerate. I'm not sure if its mechanical or the ECU, so I tried resetting the ECU by removing the battery, as well as removing the fuses for more than a minute. It still drives slower. Also when I floored it it was quite cold as well I'm not sure if this is a factor to the problem. Has anyone had this problem?? Please Help, I want to get it back to fast acceleration. Just to add I don't think the car is on "Limp Mode" as well. Its an 06 Lexus Is 250 Manual.
Old 01-02-19, 10:53 AM
  #62
MikeFig82
MikeFig82's Avatar
I would say you dumped the clutch, over reved to redline? If it's slipping now then that's probably your delay. The clutch is a wear, and tear item.
Old 01-02-19, 02:55 PM
  #63
Migeru
Migeru's Avatar
I just replaced the clutch a couple of months prior to the "incident". At first I thought it was the clutch but thats not the case after taking it to a mechanic. He said that everything seems fine but I know my car, it was faster before.
Old 01-02-19, 04:28 PM
  #64
MikeFig82
MikeFig82's Avatar
Try doing some basic maintenance. New Air filter, Clean the MAF with CRC cleaner, Clean the throttle body, new PCV valve. If you want to get deeper get a new set of spark plugs. The OEM are good for 60K miles.
Old 01-02-19, 05:14 PM
  #65
Migeru
Migeru's Avatar
Yeah Ill give those a go! Thanks for your assistance!
WolfManRCF
RC F (2015-present)
10-15-17 06:29 PM
TuCt
CT 200h Model (2011-2017)
12-10-12 02:39 PM
sahara78
05-26-08 08:29 AM
dannygjatt
04-25-08 03:09 PM
jracerlmn
01-13-06 01:23 PM
Quick Reply: ECU Computer Reset Today at 5K Service
