Driving Review
#31
Anyone with an 07 with the VDIM switch find it ineffective and how it doesn't stay off. I press the button, the light comes on, 10 seconds later the light turns off. I try holding the button for 5-10 seconds, I hear the beep as if it is really off(light coming on again). Same thing happens, 10 seconds later the light turns off again. I know the VDIM isn't really off because later the VDIM warning light will come on acting as if it just saved my life.
I really hate the paddle shifters during a hard U- turn with oncoming traffic. Try making the 1-2 shift quickly while the steering wheel is spinning thru your hands. The paddles should be stationary regardless of where the steering wheel is.
#32
Ho Motorsports
The problem is if you're going too fast to stop completely before an obstacle, you just want to slow down, then let off the brakes, then steer out of the way. If the brakes are still being applied in full force when you let off the pedal, your car is probably going to understeer pretty badly... You're going to go plowing into whatever is sitting in front of you.
Terrance
#33
Brake assist is designed to insure you get maximum braking in an emergency braking situation, even if you unknowingly let up on the brake pedal. Because it is linked to the anti-lock and brake-force distribution systems you are guaranteed to stop ASAP regardless of road conditions and/or drivers input under a panic stop and still have control of the steering.
#34
Well,you are talking about VSC and Breaking.And changing you suspenion set up would effect every part of the cars VSC and breaking!With the right setup who would need VSC.I do understand that the topic is how VSC dulls the fun factor,but my point is ,with changes to the car the effect of VSC isn`t noticed.
#35
I know what you mean though .... if your turning right or left, and want to go fast off the line (from a full stop) you need to start in 2nd ..... it actually starts in first gear anyway.
The real question is has anyone tried to "out shift" the automatic transmission .... i highly doubt anyone can get up to 60mph faster shifting manually. Anyone tried to compare?
KC
#37
i have an issue with it also... this is a great car if you dont' know how to drive at all...
in terms of feedback.. i think it's lacking... when i'm on a freeway take those wide turns at 80mph (changing freeway) .. i can't seem to trust the car... i don't consider this car a great performance car at all... i guess i really have to take it to a track and push the car to its' limits in order to know how the car responds.... i tried to spin out on purpose once , but the computer got in the way and stole all my power.. i was so annoyed... straight line.. i can't complain...
for normal driving.. i can't complain... if you let the car just take over...it almost drives for you...
#38
If a person understeers while braking and attempting to turn, its more than likely because they were going too fast in the first place as you eluded to in your post. If one is going too fast, then it would make most sense to brake in a straight line, taking into account that the car is going to implement its electronic assist. If this isn't taken into consideration, then IMO its driver error.
#39
#40
I can't say that has ever been the case with me. If I use moderate brake pressure, thats what I get. If I release the brakes, regardless of how much brake boost has been applied, the car stays predictable and I as the driver maintain control so long as the speeds are within reason. The only exception, is that my vehicle is equipped with the pre-collision system, so it starts readying the brake system before the potential impact; even then, its not an issue. In the few cases I've had to make quick lateral movements under intense braking, it hasn't been a problem since the tires traction limits haven't been exceeded (thanks in part to its ABS).
And it also doesn't sound to me like you've been in the kind of situation I was describing, anyways... If so, you handled it pretty well, I guess.
#41
lobuxracer: You sound surprised... Which surprises me...
Did you really think Toyota would let you disable all the nannies? Did you really think you could enjoy yourself on the PCH in a Lexus? Of course you didn't... You were optimistic, and maybe even trying to give the benefit of the doubt, but comon, you knew what the end result would be...
The IS-F is the only hope for a "sporty" lexus, but I doubt they will get it right... Unless they take the route that Mercedes did with AMG... In the AMG, the paddle shifters are AWESOME... They shift so damn fast... It's incredible...
And of course, BMW's M3/M5/M6 are great handling cars...
The fact that the IS350 is so smooth and comfortable while crusing down a highway is the reason you're going to have that body roll... (caymandive: you hit the nail on the head, a thicker sway bar would make things MUCH better for handling, but then the ride would be more jarring for straight freeway)
In the end, if you want something that is fun in the twisties, the IS350 is not that car...
But hey, that's why we own more than one car right?
#42
It's possible to be going too fast to slow down completely before an obstacle, but not too fast to be able to avoid the obstacle... But yes, it is also possible to avoid the kind of danger I was talking about by either always having control over how much brake pressure you apply (and never slamming the brakes in a panick) so that brake assist doesn't kick in, and/or completely releasing the brake pedal before you turn. Still, the system seems unnecessary, and CAN cause problems. Hell, someone in this thread already gave an example of them running into that problem.
BTW, I completely understand what you mean. My FD doesn't have near the electronic nannies that the IS does, but its the same logic. Regardless of how much brake pressure I apply or try to moderate, the tires have a max grip that can be exceeded while trying to make lateral movements during panic-braking. ABS attempts to prevent lock-up (better than most drivers will admit to), while providing better control over lateral movement. Brake boost is tied directly into this system in the IS, so unless its specifically overcoming the ABS by providing more brake power than allowable traction, I'd have to say it wouldn't be intefering with anything that the driver didn't initiate-- i.e. a situation for understeer.
#43
Even if the tires don't lose traction while slowing down in a straight line, you can (and will) still understeer if you're braking at full force from a high speed when you start to turn. Just because your wheels are providing enough traction to brake does not mean they are going to provide enough traction to both brake AND turn.
By the way, to Technique, and everyone else talking about the IS's handling limits... I can't really speak much from personal experience (yet) since I haven't pushed the car very hard other than on a straight line, but every review I've heard from a reputable publication has said that the ISx50 has a very capable chassis, but the problem is mainly that the nannies keep you from ever reaching it's limits. That plus, the suspension is of course a little soft and high, but that's easily fixed.
Hell didn't Team Lexus use an unmodified chassis in their Lexus IS RACECAR??? (other than suspension mods, of course) I can understand the complaints about all the software that keeps you from having fun, but I always thought the car at it's core was a very capable machine.
