Oil Viscosity
the dealership is probably lying about it because the still have a large amount of 5w-30 oil left instock.
I am running 5w-30 mobil1. I am sticking with it because here in the central valley it gets to about 110 and that will fry the engine oil when you are stuck in traffic. 5w-20 is great on start-up especially in cold part of the country. The oil will break down very fast in the summer heats like mine here.
Tech Info Resource
If you lost nearly 10% on your mileage, what did you gain?
Tech Info Resource
So you don't mind the engine running hotter, making less power, and using more fuel than it should because it makes you feel better? OK.
Tech Info Resource
My problem? I don't have a problem. I'm not second guessing the engineers who set up all the clearances in the engine and designed it to run on 5w-20 oil. You feel better because you're running 40 weight oil, but it is robbing power, using more fuel, and running hotter (check your cylinder head temps, not your gauge - the gauge is worthless for anything but grossly overheating).
I've seen guys who do this lots of times, and their decisions are based on how they feel, not how the engine performs. Your engine doesn't appreciate thicker oil and it is no better protected by 40 weight than it is by 20 weight. If you're giving up 2 mpg, that's nearly 10% less fuel mileage. Doesn't that make you wonder how much horsepower you're losing as well? Why would you want to do that?
Any suggestions for the HOT southwest area during the summer heat (115+)?
I just put in 5W-20 M1 EP when I bought the IS350 (with 7K miles on it at the time...have no idea what was in it, but better safe than sorry). However, when May rolls around and it starts to get hot as hell here, I'd be curious as to recommendations on weight for the summer months. Stick to the 5W-20 or what? Thanks all.
If so I would switch to 5w-30 max. You are running synthetic
Your good to go!
Tech Info Resource
^^Lexus recommends 5w-20 under all conditions. The cooling system on the car is more than adequate to maintain normal operating temperatures under normal conditions. If you are tracking your car, you might want to run 5w-30 or 10w-30 Group IV or Group V synthetic since it needs no VI modifiers to meet the 10w-30 specs, but for street driving, the recommended oil is 5w-20 period.
OK, summarizing from posts above..
so, 5W-20 gives better MPG, quicker at startup, but worse for track racing?
5W-30 has better performance for track racing? it is heavier so slower at startup (maybe this is why the gauge is so slow to go up in cold start)
