Yet Another DIY Oil Change for IS350 (w/pics)
Old 05-15-13, 02:42 PM
  #121
scharmack
scharmack's Avatar
Fantastic write up THANK YOU!!!
Old 09-24-13, 03:11 PM
  #122
WTBIS350
WTBIS350's Avatar
Need a quick answer cause i'm in the middle of doing my oil change. I cant find the oil drain bolt crush washer, and it looks like the lexus dealer who did my oil change last didnt even install one. Am i supposed to have a crush washer? or does it not need one. I've done oil changes on other cars and i've always installed a metallic crush washer.
need to know asap before it gets dark out, thanks!
Old 09-24-13, 03:22 PM
  #123
4TehNguyen
4TehNguyen's Avatar
it helps to have one to relief stress on the threads. If you have another car, you can find a crush washer pack at autozone, one of them should fit
Old 09-24-13, 03:43 PM
  #124
WTBIS350
WTBIS350's Avatar
nah it's just my luck that we have like 4 cars in this household and nobody is around.
I thought that i might be ok since the drain hole is raised. I thought it was the washer that was stuck to the pan, but after trying to pry it off i figured that it was the surface of the drain hole. Also i will check the container i drained it into again. But if nothing is in there then that means that the lexus dealer who did the last oil change on it didnt install a crush washer as well.
Since i'm so paranoid about it i could finish up like normal and change the filter and put new oil in. Drive my car to the autozone get the crush washer and drain the oil, put the washer in and recycle the oil (which is new anyways). Or i might just say eff it and get it installed in a couple thousand miles when i change my oil again.
Old 09-24-13, 04:52 PM
  #125
f111f444
f111f444's Avatar
Nice job. thanks.....
Old 09-24-13, 05:41 PM
  #126
4TehNguyen
4TehNguyen's Avatar
it could stay leak free without a crush washer, dont tighten it too much but try to see if you can get it to be leak free without a washer. Can buy some time until you get yourself some
Old 09-24-13, 06:41 PM
  #127
mandyfig
mandyfig's Avatar
When I changed my oil last week, I thought whoever did it before me did not have a crush washer. Lo and behold it was stuck on the opening. I just put back the plug and no leaks. I had a spare but it looked ok. As long as it is torqued right not tight not loose, it will hold up. I change the washer every 2 or 3 changes when I see the washer fully crushed.
Old 09-24-13, 08:37 PM
  #128
WTBIS350
WTBIS350's Avatar
I'll just make sure a new washer is on there when i do my next oil change. In the meantime i'll be sure to check for leaks.
Old 01-11-16, 08:55 AM
  #129
rgonza1
rgonza1's Avatar
Great write up. I use 4 Rhino ramps since I prefer my vehicle at flat level and I've also noticed getting a better drain for the old oil.
Old 01-11-16, 11:17 AM
  #130
mandyfig
mandyfig's Avatar
Quick check, oil change not due until 800 miles. All looking good.
Snuck in a car wash even though the forecast said freezing rain!
Attached Thumbnails Yet Another DIY Oil Change for IS350 (w/pics)-is.jpg   Yet Another DIY Oil Change for IS350 (w/pics)-is2.jpg
Old 04-03-16, 03:44 PM
  #131
mandyfig
mandyfig's Avatar
How do you reset the light again?
1.Odometer Must be in Total trip display
2. Turn the car off
3. Hold the Odometer button down and continue to hold throught all steps to follow
4. Do NOT put your foot on the brake
5. Push the ignition button twice. Do not hold
6. Watch the display (continue to hold the Odometer button)
7. The Oil Maintenance light will reset after a few seconds
8. Finally, release the odometer button.
Old 11-04-18, 05:00 PM
  #132
Sassper
Sassper's Avatar
Sorry to bump an old thread, but I just recently purchased an IS350 (2011), and about to do first oil change - Looking online and in this thread, I can't seem to find any info about a gasket for the oil plug. Is it not necessary? If it is - can someone please provide the part #? I am finding mixed results with part number 90430-12031, Amazon says it fits, MyLParts says it doesnt...any help is greatly appreciated!
Thanks,
~Sass
Old 11-04-18, 05:55 PM
  #133
Zmon
Zmon's Avatar
Thanks,
~Sass
That's correct.
Sassper (11-04-18)
Old 09-26-21, 05:41 AM
  #134
amadaz2000
amadaz2000's Avatar
Smile
Hi guy,
please can i use 0w-40 for my nx200t oil change
altezzza
08-13-20 05:45 AM
block232
NX - 1st Gen (2015-2021)
23
02-18-20 07:57 AM
rlx101
26
12-22-14 07:27 PM
pizdets17
10-03-10 05:37 PM
IS350atWOT
IS F (2008-2014)
08-17-10 01:54 PM
Quick Reply: Yet Another DIY Oil Change for IS350 (w/pics)
