Illuminated Scuff Plates
Here. But im waiting for some to actually confirm for me that the 07s really are just plug n play.
2IS OG
Yes. It is plug N play for all '07 model. Just installed mine 3 weeks ago. Bought them from Luis @ Carson Toyota. Took me less than 10 minutes to install. Pull the old ones, plug the harness, and snap back new illuminated scuff plates. When you pull out the old ones, pull from an angle. From inside out, then pull the outer doorsill upward.
Javier
I have prem package. BUT talked to Luis and he confirmed ALL '07 models, regardless of option packages, ISP are PNP.
I have prem package. BUT talked to Luis and he confirmed ALL '07 models, regardless of option packages, ISPs are PNP.
Only the fronts ones are illuminated. You can buy the rear plates with "Lexus" but they're not illuminated. No wiring to the rear ones per Luis. Rear plates $64 each + tax @ Carson Toyota.
My bad. Apparently rear plates are aluminum plates without "lexus" per IS2506spd.
I just installed mine tonight. Took me less than 10 minutes. It was super easy, especially once I got the first one done. They look awesome. Cant wait to show em off!
2IS OG
Javier
