Splash Guards For Isx50?
Does anybody know if "Splash Guards" exist for our IS's? i am tired of washing my car and dressing up my tires and after driving for a while, the sides of my car end up with thousands of black dots from the tire dressing
thanks in advance!
thanks in advance!
An aftermarket chemical product called “tire dressing” is sometimes used on tires. When the tire dressing is applied, it may combine with an anti-ozonant compound (applied by tire manufacturers) to form a new compound that could stain vehicle paint. The paint stains occur if the wet tire dressing/anti-ozonant compound slings onto the vehicle paint when the vehicle is driven.
Paint damage stains caused by application of the tire dressing are NOT covered by warranty.
2IS OG
The OP can solve this "splatter" problem by putting less tire dressing on. It only takes a thin coat of tire dressing to do the trick. Also, try to put in on when you know you're not going to drive you car for a while, so it has a chance to dry a bit before you start spinning tires.
Javier
Javier
2IS OG
http://www.infinitihelp.com/Ownershi.../ITB05-003.htm
Javier
