Wanting to install sub+amp using factory head unit, HELP!
#31
No cutting, just disconnect the harness from the sub and then tap into the harness. I tapped into all 4 wires since my converter is 2-channel. Brown/Green goes into one channel, Pink/Blue to the other. You don't have to worry which channel is left or right.
#39
I attempted to do that today, I was going to run the power wire thru the grommet wiht all the wires running thru it, but it looks almost impossible to run it thru and get it into the passenger side. i dont have enough patients for this lol
#41
1. remove battery
2. take a metal hanger, cut it and straighten it out
3. tape one end of hanger with the power wire
4. stick the other end through the large grommet
5. have another person inside the car on passenger side guide it through and pull it out (remember to remove the scuff plate and side molding first)
I would highly recommend before putting the battery back on to upgrade the ground wire from chasis to negative. If you dont have any idea why, go to caraudio.com forum and search for "the big 3", or go to a local car audio shop and ask why. Upgrading the ground is one of the big 3 (I didn't do the other 2 because its too much of a hassle and I dont think its neccessary for our new car, although many on that forum will disagree but whatevers).
RobertE
23
08-19-15 07:00 AM
Rawsten
03-11-13 07:27 AM
folsep
05-05-10 03:04 PM
dusouth
05-03-07 12:23 PM
