Guess who gets to take their IS on a Formula 1 track?? hehe
So, I found out there is a race track about 1 1/2 hour from my home. And apparently they offer schools in the summer. The race track is called Mid-Ohio. Their website is www.midohio.com, I would check it out if I were you, its sweeet. So I am going to take some advanced driving classes there this summer, and I can use my own car, which obviously I will. It is going to be sick!! Only 2 months away!
Question:
For some of you more experienced drivers/people who have been on a track before, should I do anything to my car to make it better suited for the track? what about tires, wheels, anything at all? should I invest in some of the chassis braces that they have on l-tuned parts? lemme know what ya'll think.. thanks
Edit: it's might not be an F1 track, but it is still freakin' awesome.
Question:
I thought it was...who knows, they have some picures of F1's on there. But whatever the case may be...it is still going to be sweet. especially having a professional driver teaching you how to drive on a track, I think it will be fun as hell. definately worth the $675
1. I usually pump up the tires a little more than what's recommended (usually about 4-5 lbs.)
2. go with a full tank of gas
3. If they don't rent helmets, get the best and lightest one you can afford. You only have 1 head.
4. have at least 3/32nds of tread left on your tires
Most of the other stuff you'll have to know will be on the materials they send you.
If this is your first time out, I really wouldn't bother upgrading anything. If and when you go out again and start to progress and want to pursue this further, that's when you'll know exactly what needs to be done to the car.
Have fun and see what the IS can do.
Liquid Bra Champion
Probably Formula 2000. Only F-1 in USA is Indy.
Let us know how the 250 brakes do. A friend took his A4 to a track day and completely ruined the brakes. Rotors turned blue from overheating, and completely wore out the pads.
Tech Info Resource
You might want to consider brake pads oriented toward operation at the hot end of things. The IS is a heavy car and it won't take a lot to fade the OEM pads. Other than that, keep the rubber side down and it will all be good.
I am going to have the EBC GREEN STUFF installed in the next month or so. I dont think the IS250 has enough power to warrant the RED STUFF. What do ya'll think?? OR what pads should I install?
I would honestly recommend EBC Red Stuff over the Green Stuff. The Red Stuff is for more heavy duty braking which is what you will be doing around the turns....better to be safe than sorry. Review it 100% before you go through it. Good luck and let us know how you do.
Yea since I havent had any classes or track time there before, the first time I go there I have to take the advanced driver class and all that. I will take baby steps and learn everything before they let me out there by myself. It is mostly instruction until I am ready to go solo. but all in all it is really just instruction, but still. it'll be sweet.
Mid-Ohio is used for American Le Mans Series and the Porsche Cup.
I'm gonna try and hit up Limerock in CT and Englishtown Raceway (if they ever finish construx)
Good luck to you and try EBC Redstuff paired with Michelin PS Cups shaved to 6/32
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
I'd recommend upping the quality of your brake fluid to a synthetic with a higher boiling point. I like ATE Super Blue but Motul and Valvoline make good stuff as well. Flush it with the new stuff just before you go.
Get yourself one (or two, since you'll have an instructor) of these devices for your seatbelt since you won't have a race shell, high bolster seat or multi-part harness. Will help keep your belt cinched down and hold you in your seat in corners.
http://www.cg-lock.com/
