Ceramic Tint - Mirror effect?
Just to make sure I have this straight - ceramic tint gives off a slight "mirror" effect, right? Metallic tint does not? While I do like the fact that ceramic tint has better heat repelling abilities, I do not want it to look like a mirror.
In Texas, the law is 25% Front, 25% Rear, ANY % Rear Windshield. I'm thinking about doing 25% all around and 60% on the front windshield.
Mine doesn't look like a mirror ... I've got 40% Llumar ceramic all around (minus the front windshield) ...
Not only is the ceramic better at heat rejection ... it also doesn't interfere with the FM and GPS reception (so I've been told) ... it was about $100 more than the regular Llumar ... when I had it installed a few weeks ago.
Koz
you can really feel the difference between ceramic tint and dyed tint. the tint shop i went to had a huper optik demo box with a heat lamp in it. it allowed you to feel the heat rejecting difference between ceramic tint and regular dyed tint.
i have 40% ceramic tint and it doesn't look like a mirror. i can imagine if it was darker it might look like a mirror? at some angles you can see the reflection... it's comparable to the reflection you get from the window sills.
I wanted the Huper Optik tint ... but my shop only uses Llumar ... I'm happy with it ... it looks sharp, isn't too dark ... and helps keep the interior cooler.
I just did a search and found that there is, in fact, ceramic material in the film itself. There seems to be many benifits to this type of tint. No reflection seems to be the biggest plus.
Koz
Koz
Just found out my Lexus dealership uses DigiFilm ceramic tint. I couldn't find much on this online. Anyone know anything about it? They said there are 7 "levels" of tint. On the IS they use level 5. I don't know what that means in terms of the %.
Oh, I see. Thanks. But I'm having my dealership install the tint (they said they do it in house. I was just hoping to get some info on DigiFilm and what the Visual Throughput of the 7 different levels was.
Because of its properties, does ceramic tint typically look darker than metallic tint at a higher number? In other words, does 40% ceramic tint look similar to metallic tint at 25% in terms of its darkness? I was originally thinking about getting metallic tint at 25% but would really like the heat reflecting properties of the ceramic tint.
