How to remove the center console storage
How to remove the center console storage box?
I took apart the car this weekend to perform the nav hack, the back up camera override and Nav Video Hijack . I was hoping to find a way to tap the audio jack and 12V plug in the center console box, but couldn’t figure out a way to remove the center console storage box.
There were two screws holding down the storage box (picture below). I unscrew it, but still couldn’t remove the box. In fact, after unscrewing the two screws it didn’t even loosen the storage box.
Anyone have instructions on removing the center console storage box, or can point me in the right direction?
Thanks
Thanks
![](http://xca.xanga.com/e9cd46f541630120163726/b86487193.jpg)
No idea, but you are way braver than me.
Godspeed in getting everything back together, working properly with the desired hacks/modifications, and with no induced squeaks or rattles.
![Yikes!](https://www.clublexus.com/forums/images/smilies/yikes.gif)
Not that brave, I did it because of the great write ups on this community forum. Here's some more pictures of the mayhem. Everything is put back together now. you can't even tell this was done. I'll post up some pictures once it's all done. All in all only $20 worth of parts needed
My Goal:
1) Back up camera hijack (Done)
2) Car moving Nav Override (Done)
3) Video in (Done)
4) Carputer (Car computer) (Not done) : need help on removing the center console storage box, so I can tap the 3.5mm Audio Jack
![](http://x6f.xanga.com/044d256a39c31120264732/b86570413.jpg)
Pictures of the Relay switch
http://x4e.xanga.com/bc4d55661633012.../b86570407.jpg
More relays and wires
![](http://x5a.xanga.com/780d537339331120264716/b86570400.jpg)
More relays and wires . (BTW the i used the lighter to strip the wires)
![](http://xf9.xanga.com/8dfd527239031120264711/b86570396.jpg)
Relay close up
![](http://x37.xanga.com/2fd820e7d14b8120264710/b86570395.jpg)
Open the dash and cluster to feed the wire so i can install a button next to the sunshade
My Goal:
3) Video in (Done)
Relay close up
![](http://xcb.xanga.com/029822e6d14a8120264700/b86570386.jpg)
