What amount of orange peel is acceptable on repainted door?
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I had my '06 IS350 in to fix the engine cranking noise last week. They kept it for 7 days. They fixed that problem but when I got it back there was a giant ding dead center of the passenger front door. The service mgr said they'd make it 100%. I left it there for 3 days. Got it back today. The door has been repainted but there is a significant amount of orange peel (my opinion). If you look at your reflection in the front door versus the back the outlines of your legs are mottled. He assured me that no corners were cut and that it was done at a considerable expense to the dealer. I'm sure that's the case.
Here's my question. What amount of orange peel should I reasonably expect? I know to the trained eye that it will always bear evidence of a repaint. But I don't know anything about painting and it's obvious to me that it has been repainted. Honestly, if I had known it would turn out like that I would have had them touch it up and then have a it wetsanded and buffed. I don't know if I'm being unreasonable or not. I'm looking for honest opinions here. Not "damn the dealer you should sue them" type posts. Never knew a ding on a car could make me so darn crabby.... I guess what I'm most frustrated about is the diminished resale value of the car. This is the first car that I'm not going to "run into the ground". I was planning on trading it in in about 4 years and moving to something even more powerful. Of course in 4 years, the difference will probably be negligible. Looking for advice.
The repaint should not have any more orange peel than the factory finish, or it will stick out like a sore thumb. If the dealer tries to tell you that they can't fix it, tell them that you want them to pay for you to take it to someone that can. It's just pure laziness...they need to learn how to wetsand properly.
I had a similar situation when my car was vandalized (crease in the step just below the window line). I noticed that there was more orange peel in the repaint than in the factory paint. I took it back to my body shop (which I highly esteem), and was told that the amount of orange peel is entirely based on the wetsand. Usually a body shop tries to match the 'orange peel' to that of the original paint, since all paint has at least a little texture to it. He said that they could very easily wetsand it to a finer texture to match it up.
Hopefully that helps.
Super Moderator
I've noticed a lot orange peel on my factory colored "Smokey Granite Mica" car. But you have to look at it at an angle. I don't think I'll worry too much about it.
orange peel can be removed by wet sanding and buffing with 3M's buffing compound. No need to repaint. Now, "fish eyes" are a bigger problem to fix. A good detailer can remove the orange peel. You don't want to remove too much because it will not match the rest of the car.
I don't think wet sanding on top of clear will fix the issue. I believe the issu is with the opaque paint underneath, not the clear on top. Am I right in saying that they'd have to repaint, wet sand, then clear on top to fix?
Hmm.... haven't heard of "fish eyes", DJ. If I had to name the issue I have right now I think that "fish eyes" might be a better characterization. To the other poster that said his factory finish has orange peel, that is to be expected. A small amount is standard. But the difference between a factory painted panel and the one that was just repainted is truly night and day. Very frustrating... First they had to rip my cam shaft out to fix that darn startup noise and now I have to deal with this.
